I have a device with a WiFi access point (USB dongle) and an ethernet port that connects to a switch and then lots of other devices. I want my balena device to to DHCP and DNS for all ethernet AND WiFi clients. I could not figure out how to put 2 different interfaces on the same subnet so I have a subnet with dnsmasq instance for each interface.
WiFi AP config:
[connection]
id=balena-hotspot
uuid=36060c57-aebd-4ccf-aba4-ef75121b5f77
type=wifi
autoconnect=true
interface-name=wlp0s20u4
permissions=
secondaries=
[wifi]
band=bg
mac-address-blacklist=
mac-address-randomization=0
mode=ap
seen-bssids=
ssid=somehotspotssid
[wifi-security]
group=
key-mgmt=wpa-psk
pairwise=
proto=rsn
psk=some-password
[ipv4]
address1=10.42.0.1/24
dns=127.0.0.1;
dns-search=
method=manual
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
dnsmasq \
--address=/#/10.42.0.1 \
--dhcp-range=10.42.0.1,10.42.0.254 \
--dhcp-option=option:router,10.42.0.1 \
--interface=wlp0s20u4 \
--bind-interfaces \
--except-interface=lo \
--conf-file \
--no-hosts \
--log-facility=-
Ethernet
[connection]
id=pci-eth-1
type=ethernet
interface-name=enp3s0
permissions=
secondaries=
[ethernet]
[ipv4]
address1=192.168.30.1/24
dns=127.0.0.1;
dns-search=
method=manual
[ipv6]
dns-search=
method=auto
dnsmasq \
--address=/#/192.168.30.1 \
--dhcp-range=192.168.30.1,192.168.30.254 \
--dhcp-option=option:router,192.168.30.1 \
--interface=enp3s0 \
--bind-interfaces \
--conf-file \
--no-hosts \
--log-facility=-
The issue
When I connect to the WiFi AP, dnsmasq on the balena device will allocate a 10.42.0.X IP. Unfortunatley I cannot then ping any ethernet device running on 192.168.30.X. Similarly, ethernet devices cannot ping WiFI devices.
Possible solutions?
- If there some way to only have 1 dnsmasq instance that manages both the eth and wifi interfaces? Then I would not need to communicate accross two subnets.
- Can I create some sort of bridge between these two subnets so every device can access every other device?
Thanks so much for any advice!
