Compulab Balena Image flash doesn't work anymore
Hey there, with the latest Hardware versions the Compulab Image flash doesn’t work anymore.
I used always this and it worked without any problems in the past.
Used hardware: IOTDIN-IMX8P 2GB DRAM
console log shows:
pca9450@25 [ldo4][u] = 1v8
DDRINFO: EEPROM VALID DATA [ [ cafecafe ] = 1080010 2
DDRINFO: Cfg attempt: [ 1/6 ]
DDRINFO(?): deadbeaf 2048MB @ 3000 MHz
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
DDRINFO(M): mr5-8 [ 0x1080010 ]
DDRINFO(T): mr5-8 [ 0xdeadbe▒pca9450@25 [ldo4][u] = 1v8
DDRINFO: Cfg attempt: [ 2/6 ]
DDRINFO(?): Samsung 4096MB @ 3200 MHz
DDRINFO: DRAM rate 3200MTS
Training FA▒pca9450@25 [ldo4][u] = 1v8
_spl_dram_init Bad attempt 3 skip
DDRINFO: Cfg attempt: [ 4/6 ]
DDRINFO(?): Micron 4096MB @ 3000 MHz
Training FA▒▒pca9450@25 [ldo4][u] = 1v8
_spl_dram_init Bad attempt 5 skip
DDRINFO: Cfg attempt: [ 6/6 ]
DDRINFO(?): Samsung 2048MB @ 3000 MHz
DDRINFO(T): mr5-8 [ 0x10610▒pca9450@25 [ldo4][u] = 1v8
DDRINFO: Ran out all [ 6 ] cfg attempts. A non supported configuration
Maybe they changed the RAM chip and you have to provide a newer Balena release version?
Thank you for your help.
Kind regards
Timo
I’ve analyzed the latest firmware boot version.
https://mediawiki.compulab.com/w/index.php?title=IOT-DIN-IMX8PLUS:_U-Boot:_Recovery
And i think you are missing the
Nanya chip in your images.
As you can see in their release notes, some changes are needed in the latest hardware revision and their own image.
https://mediawiki.compulab.com/w/index.php?title=IOT-DIN-IMX8PLUS:_Debian_Linux:_Release_Notes#02-Feb-2026.2C_IOT-DIN-IMX8PLUS_Debian_Linux_2.0
Can you update the BalenaOS? We use the Compulab hardware for production environments and are not able to flash any of the hardware with the latest hardware revision.
With the latest BalenaOS version (>v6.11.8+rev1) the issue is fixed.
Flashing and booting works both as expected again.
