I am trying to get balena OS to run in the VAR-SOM-IMX8M Mini Variscite board. As far as I understand the software is shared between this board and the DART-MX8M Mini, which is already supported by balena. However when I flash the DART image into the VAR-SOM I can only find the device and I am not able to ssh into it.
Should this work? If not is balena planning to add support for the VAR-SOM-MX8M Mini? If not how easy is it to add custom support for this board?
Thank you in advance
