I am attempting to build and deploy this https://github.com/balena-os/kernel-module-build as is. I’m actually attempting to build a modified mcp251x driver but I’ve backed up and the kernel-module-build project won’t build successfully on the newer versions of Balena / GCC.
I had this working a month or so ago on an older version of Balena OS. 2.75.0+rev1 but now I’m struggling.
OS Version: Balena OS 2.88.4.dev
Device Type: CM4 IO Board (custom board)
[main] 2022-03-23 15:53:13 (42.7 MB/s) - 'kernel_modules_headers.tar.gz' saved [13110176/13110176]
[main]
[main] make: Entering directory '/tmp/tmp.46Vy6IYLQR'
[main] CC [M] /usr/src/app/output/example_module_raspberrypi4-64_2.88.4.dev/hello.o
[main] gcc: error: unrecognized command line option '-mbranch-protection=pac-ret+leaf'
[main] gcc: error: unrecognized command line option '-fpatchable-function-entry=2'
[main] gcc: error: unrecognized command line option '-mstack-protector-guard=sysreg'
[main] gcc: error: unrecognized command line option '-mstack-protector-guard-reg=sp_el0'
[main] gcc: error: unrecognized command line option '-mstack-protector-guard-offset=1376'
[main]
[main] scripts/Makefile.build:280: recipe for target '/usr/src/app/output/example_module_raspberrypi4-64_2.88.4.dev/hello.o' failed
[main] make[1]: *** [/usr/src/app/output/example_module_raspberrypi4-64_2.88.4.dev/hello.o] Error 1
[main]
[main] make: *** [/usr/src/app/output/example_module_raspberrypi4-64_2.88.4.dev] Error 2
[main]
[main] Makefile:1825: recipe for target '/usr/src/app/output/example_module_raspberrypi4-64_2.88.4.dev' failed
[main] make: Leaving directory '/tmp/tmp.46Vy6IYLQR'
[main] Removing intermediate container 5141306ef4b7
[main] The command '/bin/sh -c ./build.sh build --device raspberrypi4-64 --os-version "$VERSION" --src example_module' returned a non-zero code: 2
[Info] Uploading images
[Error] Service: main
[Error] Error: The command '/bin/sh -c ./build.sh build --device raspberrypi4-64 --os-version "$VERSION" --src example_module' returned a non-zero code: 2
[Info] Built on arm01
Remote build failed
I attempted to use update-alternatives to use GCC 9 but a I get a different error with that.
FROM balenalib/raspberrypicm4-ioboard-ubuntu:xenial
RUN apt-get update && apt-get install -y curl wget build-essential libelf-dev awscli bc flex libssl-dev python bison
COPY . /usr/src/app
WORKDIR /usr/src/app
RUN apt-get update && apt-get install software-properties-common -y
RUN add-apt-repository ppa:ubuntu-toolchain-r/test && apt-get update && apt-get install -y gcc-9 g++-9
RUN update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-9 60 --slave /usr/bin/g++ g++ /usr/bin/g++-9
ENV VERSION '2.88.4+rev0.dev'
RUN ./build.sh build --device raspberrypicm4-ioboard --os-version "$VERSION" --src example_module
CMD ./run.sh
That results in this
[main] 2022-03-23 16:12:10 (21.8 MB/s) - 'kernel_modules_headers.tar.gz' saved [13110471/13110471]
[main]
[main] make: Entering directory '/tmp/tmp.HcRkmzPMww'
[main] CC [M] /usr/src/app/output/example_module_raspberrypicm4-ioboard_2.88.4+rev0.dev/hello.o
[main] Assembler messages:
[main] Error: unknown architecture `armv8.4-a'
[main] Error: unrecognized option -march=armv8.4-a
[main]
[main] scripts/Makefile.build:280: recipe for target '/usr/src/app/output/example_module_raspberrypicm4-ioboard_2.88.4+rev0.dev/hello.o' failed
[main] make[1]: *** [/usr/src/app/output/example_module_raspberrypicm4-ioboard_2.88.4+rev0.dev/hello.o] Error 1
[main]
[main] make: *** [/usr/src/app/output/example_module_raspberrypicm4-ioboard_2.88.4+rev0.dev] Error 2
[main]
[main] Makefile:1825: recipe for target '/usr/src/app/output/example_module_raspberrypicm4-ioboard_2.88.4+rev0.dev' failed
[main] make: Leaving directory '/tmp/tmp.HcRkmzPMww'
[main] Removing intermediate container bbe076a369d4
[main] The command '/bin/sh -c ./build.sh build --device raspberrypicm4-ioboard --os-version "$VERSION" --src example_module' returned a non-zero code: 2
[Error] Error: The command '/bin/sh -c ./build.sh build --device raspberrypicm4-ioboard --os-version "$VERSION" --src example_module' returned a non-zero code: 2
[Info] Built on arm06
Remote build failed
When I attempted to build the example_module without docker on a CM4 I running the same version of Balena OS / Ubuntu:Xenial I get the same error.
Any help is greatly appreciated.
Kyle
