system
October 30, 2024, 2:53pm
1
Docker compose has a feature to support multiple or non-default “docker-compose.yml” filenames using the “-f” flag.
It would be extremely helpful to be able to change the docker-compose filename during “push” and “deploy”.
Ideally, this would support the full merging rules, but for most use cases it would be sufficient to just allow using a different filename.
The behavior in Add support for docker-compose dev overlay by srlowe · Pull Request #2177 · balena-io/balena-cli · GitHub (to merge docker-compose.dev.yml) is not sufficient to solve this because it creates confusion against the normal docker compose behavior where users would explicitly specify the files they want loaded.
system
November 8, 2024, 9:55am
4
Jonathan Berger set the status to In Progress
Hi Chris, we recognize that this is a valid use case and a long standing request from the CLI users. Our engineering team is looking at bringing the -f flag option to the CLI, we will let you know when we have updates.
