Hi!
Is it possible to add a custom /system-connections/ file for the Network manager used by the HostOs, from a separate container? For example to add a Cellular configuration file.
Thanks in advance
Hi!
Thanks in advance
Hi there! Take a look at this section of the docs, it talks about reconfiguring the network manager at runtime and may be useful! The example given is to modify wifi settings, but maybe you could extend/modify it to meet your requirements: https://www.balena.io/docs/reference/OS/network/2.x/#changing-the-network-at-runtime
thanks for that, I totally missed it. Will try it and let you know.
