I’m running a node express server after wifi-connect gets a pi zero on to a network. I would like to be able to access the express server via a_custom_name.io on the LAN instead of the device ip. I found this command that I can run in my start.sh, however balena local doesn’t find the device anymore. What should I be doing to achieve this?
curl -X PATCH --header "Content-Type:application/json" \
--data '{"network": {"hostname": "newhostname"}}' \
"$BALENA_SUPERVISOR_ADDRESS/v1/device/host-config?apikey=$BALENA_SUPERVISOR_API_KEY"
version: '2.1'
networks: {}
volumes:
myapp-data: {}
services:
audio:
build:
context: ./audio
privileged: true
restart: always
labels:
io.balena.features.kernel-modules: '1'
wifi-connect:
build: ./wifi-connect
privileged: true
network_mode: host
labels:
io.balena.features.dbus: '1'
main:
build:
context: ./main
volumes:
- 'myapp-data:/data'
privileged: true
restart: always
expose:
- "1381"
ports:
- "80:1381"
depends_on:
- audio
- wifi-connect
