New to balenaos
balenaos is running on virtualbox
cant login to balenaos … cant find IP address
New to balenaos
Hi Vivek,
Welcome to the community!
Have you followed a guide to install balenaOS on virtualbox?
It’d be good to see the steps you followed so we could see if there is something off with the guide you used.
Next, do you see the balena logo in your virtualbox? Does balenaCloud dashboard display your device?
We need to understand better at which step you are stuck.
how can I send you the screen shot ?
Does the device not show up on the dashboard?
No
Actually I haven’t done anything with respect to dashboard. No idea how to set it up.
Please share any link to document which describes how to
Hey @viveksaxena
I’m sure we can get to the bottom of this
Firstly, do you want your virtualbox instance to show up in the balena dashboard? Or are you just interested in running balenaOS on the instance?
If it’s the former, this link should be of some help: https://www.balena.io/docs/learn/getting-started
If it’s the latter, and you simply would like to find the device address to SSH into the device, balena-cli should be able to help you, with it’s balena scan command.
Please do let me know if neither of these resources help.
