Can't find .Appimage file in ISO download
I was working in Linux Lite 4.8 trying to upgrade to 6.6 . I downloaded balenaEtcher-linux-x64-2.1.4.zip and listed the files with the unzip -l command. I saw no .Appimage file there. I posted to the product support forum with title “Filename to use to make bootable USB drive?”, including a file listing. I don’t know if the moderator considered it off-topic, or was just too busy, so I’m posting here. I haven’t included the file listing here, since whoever sees this can just look it up on the product support forum (it’s long).
Thanks to anyone who can help!
Here’s a screenshot of the unzipped download.
Thanks again to anyone who can help!
I have the same issue. No executable file was extracted from the zip downloaded for a Linux 64 OS.
Just a link and a shared library (except for the folders)…
Both seem not to work on my Ubuntu 14.04 LTS… see the attached screenshot…
Please someone do respond to this…
Hello, you should be able to right click on balena-etcher (not the shortcut or link as in your screenshot, but the next one to the left) and select “Run” to launch Etcher.
I have tried that aready but as I told you instead of running the Balena Etcher I get a
window saing: (screenshot attached)
"Could not display “balena-etcher”…
There is no application installed for “shared library” files.
Do you want to search for an application to open this file? Y/N"
And even when I did say YES the system was not able to find what was needed so I am back to where I started…
Please provide me with an user-friendly solution to this issue as I am not familiar with coding nor with using the command prompt…
The very reason I need to use the Balena Etcher is that my Ubuntu version is outdated (14.04 LTS) and I need to install a recent one formatting the harddrive in the process as I did encrypt it back then but I have lost the password so no updates were possible…
Thanks in advance
Vlad
Since Ubuntu 14 was end of life almost seven years ago, it may be too old to run the current version of Etcher. I was able to get a much older version of Etcher running on Ubuntu 14. However I would suggest installing Etcher on a different newer computer/OS and using that to flash your target OS onto a removable drive. Then boot your Ubuntu 14 machine with that drive.
