Hey, without a /boot/config.txt file I don’t know if it’s possible to overclock my Raspberry Pi 4.
I have a proper fan and heat-sink so they can be stable at 1,8GHz or 1,9GHz.
Any way to speed up?
Thanks!!
Thanks. I’ll try soon.
OK, I added this in Device configuration in this order to avoid boot problems:
BALENA_HOST_CONFIG_over_voltage 4
The device reboot after adding the variable, and after booting again add:
BALENA_HOST_CONFIG_arm_freq 1900
If 1900 and 4 is to much you can try 1800 and 3
Finger cross and checking stability and performance achieved.
