The general problem I have is that I am trying to trying to load a new kernel module I built, but it appears there is a conflicting built in kernel module that I cannot remove.
Now, into the specifics. My balena setup is the following:
- Device Type: Generic x86_64
- Balena OS: v2.58.6+rev1
- Edition: Production
Hardware wise, I have a Logitech G29 Driving Force Racing Wheel connected to a Dell XPS 8940 desktop. Some of the force feedback functionality is missing in the built in hid_logitech kernel module, so I am building another kernel module for the logitech wheel from the following repo https://github.com/berarma/new-lg4ff, based on instructions from https://github.com/balena-os/kernel-module-build. On startup of my service, I try to remove the hid-logitech kernel module and insert the custom built kernel module.
rmmod hid-logitech
insmod /var/lib/dkms/new-lg4ff/0.3.1/5.2.10-yocto-standard/x86_64/module/hid-logitech.ko
However, I get the following errors that the hid_logitech module is builtin to the linux kernel and cannot be removed. Then, the custom built kernel module fails to load because the device already has the builtin kernel module.
rmmod: ERROR: Module hid_logitech is builtin
insmod: ERROR: could not insert module /var/lib/dkms/new-lg4ff/0.3.1/5.2.10-yocto-standard/x86_64/module/hid-logitech.ko: Device or resource busy
Any advice on how I can use my custom built kernel module that seems to conflict with the builtin kernel module?
