Hello everyone,
I am a real newbie on Balena and I stumbled upon it after trying to create my own lorawan gateway. That is still ongoing but in the meantime I discovered that Balena offers a lot more and as I have another project idea, I thought that Balena might be the perfect solution. I want to combine my own home automation dashboard which runs in node-red to be displayed on a dedicated raspberry pi. It will also have an audio client with a dedicated user-interface that can play internet radio and spotify sources, also running in node-red. I have the flows ready to do that. The radio is just an html audio tag, the spotify client is a webpage in node-red which uses the web-api to control a running spotify client. This all works pretty good on an android tablet, including controlling the audio volume. My idea now is to create a new balena project based on balenaDash and add the node-red block and the sound block. Then I want to develop the flows in the project itself so they will be installed when deploying the image. An alternative would be to separate the ui and the streamer to 2 different PI’s, is that better?
I know it sounds like a long shot but I hope anyone of you can point me in the right direction whether this is the way to go. Any tips would be greatly appreciated.
Thank you all in advance,
Ronald Brinkerink
