Hi Balena Community,
I’m attempting to bring up BalenaOS on a custom Rockchip RK3588-based board. I successfully built the image:
balena-image-flasher-rk3588-rock.balenaos-img
However, when I flash this image to eMMC and try to boot, I’m hitting an issue during the U-Boot SPL stage. The board repeatedly shows the following logs:
U-Boot SPL board init
U-Boot SPL 2017.09-ge4e124926e-230922 ...
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC: no card present
mmc_init: -123
spl: mmc init failed with error: -123
Trying to boot from MMC1
No misc partition
sys malloc pool space exhausted
alloc_read_gpt_entries: ERROR: Can't allocate lX bytes for GPT Entries
GPT: Failed to allocate memory for PTE
This repeats endlessly. From what I understand:
- U-Boot SPL is running but can’t detect the MMC properly.
- GPT parsing fails likely due to allocation errors (
sys malloc pool space exhausted). - I’m using the Rockchip DDR/ATF binaries and U-Boot from the SDK.
- This same DDR+U-Boot combo works fine when booting a standard Linux Yocto(Kirkstone) build.
The GPT of the flasher image looks like this (via gdisk):
Number Start (sector) End (sector) Size Code Name
1 64 8063 3.9 MiB 8300 loader1
2 16384 25599 4.5 MiB 8300 loader2
3 81920 344063 128.0 MiB EF00 flash-boot
4 344064 2949119 1.2 GiB 8300 flash-rootA
5 2949120 2957311 4.0 MiB 8300 flash-rootB
6 2957312 2965503 4.0 MiB 8300 flash-state
7 2965504 2996223 15.0 MiB 8300 flash-data
This same board boots fine with a minimal Yocto image built using Rockchip’s BSP (same U-Boot and DDR binaries).
My questions:
- Is there anything specific BalenaOS expects in the bootloader or partition layout that I might be missing?
- Could the issue be due to how the
balena-image-flasheris packaging or offsetting the boot files? - Are there known memory pool limitations in U-Boot SPL that need to be increased for Balena’s default image size or structure?
- Has anyone successfully built and booted BalenaOS on RK3588 and can share working config fragments or hints?
Any guidance or direction would be really appreciated.
