Build from github URL
We have a dependency in a multi-container docker-compose.yml on a github repo, which seems to not work on balena build? Is this not supported? I couldn’t find documentation on this, but it is supported by version 2 of docker-compose. The dependency is for logspout and the docker-compose.yml lines look like this:
  logspout:
    build:
      context: https://github.com/notnamed/logspout.git#master
      dockerfile: Dockerfile.template
    command: 'syslog+tls://logs34.papertrailapp.com:11168'
    labels:
      io.balena.features.balena-socket: '1'
The output from the build says this, seems like it doesn’t attempt to do the git checkout?
Enumerating objects: 3060, done.
Counting objects: 100% (3025/3025), done.
Delta compression using up to 8 threads
Compressing objects: 100% (924/924), done.
Writing objects: 100% (2984/2984), 7.31 MiB | 900.00 KiB/s, done.
Total 2984 (delta 1860), reused 2910 (delta 1795)
remote: Resolving deltas: 100% (1860/1860), completed with 30 local objects.
[Info]           Starting build for playground, user jt
[Info]           Dashboard link: https://dashboard.balena-cloud.com/apps/xxxx/devices
[Error]          Could not detect project type: Service logspout: Specified file not found or is invalid: Dockerfile.template
[Error]          Not deploying release.
I’m afraid our builder doesn’t support this use-case. I guess a way would be to import that logspout repo into your main source.
I’ll raise internally to update the docs page with this limitation
Regards
ZubairLK
