Still no go. Here’s the console output (from ttyS0) if it might have any clues.
U-Boot SPL 2017.01-gda5f8ccd01 (Jun 16 2017 - 08:09:40)
Trying to boot from MMC1
reading u-boot.img
reading u-boot.img
U-Boot 2017.01-gda5f8ccd01 (Jun 16 2017 - 08:09:40 +0000)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: Could not get PHY for cpsw: addr 0
cpsw, usb_ether
autoboot in 1 seconds (type "stop" to abort or " " to delay)
Scanning MMC and USB devices 0 1 2
reading resin-image-flasher
24 bytes read in 4 ms (5.9 KiB/s)
Found resin flasher on mmc 0
Loading resinOS_uEnv.txt from mmc device 0 partition 1
reading resinOS_uEnv.txt
** Unable to read file resinOS_uEnv.txt **
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
12257576 bytes read in 994 ms (11.8 MiB/s)
58499 bytes read in 53 ms (1.1 MiB/s)
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 8ffee000, end 8ffff482 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.34+ (builder@ea662087cbaa) (gcc version 6.2.0 (GCC) ) #2 SMP PREEMPT Mon Sep 4 15:58:15 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: TI AM335x BeagleBone Green Wireless
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 15 pages/cpu @df92a000 s32140 r8192 d21108 u61440
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=0b017a99-02 rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 445368K/522240K available (11264K kernel code, 1092K rwdata, 4196K rodata, 4096K init, 725K bss, 27720K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)
[ 0.000000] .init : 0xc1100000 - 0xc1500000 (4096 kB)
[ 0.000000] .data : 0xc1500000 - 0xc1611088 (1093 kB)
[ 0.000000] .bss : 0xc1613000 - 0xc16c8458 ( 726 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000035] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000049] OMAP clocksource: timer1 at 24000000 Hz
[ 0.001073] clocksource_probe: no matching clocksources found
[ 0.001551] Console: colour dummy device 80x30
[ 0.001580] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001589] This ensures that you still see kernel messages. Please
[ 0.001597] update your kernel commandline.
[ 0.001623] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.046709] pid_max: default: 32768 minimum: 301
[ 0.047011] Security Framework initialized
[ 0.047028] Yama: becoming mindful.
[ 0.047072] AppArmor: AppArmor disabled by boot time parameter
[ 0.047284] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047298] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048509] CPU: Testing write buffer coherency: ok
[ 0.048585] ftrace: allocating 37639 entries in 111 pages
[ 0.154989] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.155069] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.198734] Brought up 1 CPUs
[ 0.198763] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.198773] CPU: All CPU(s) started in SVC mode.
[ 0.200410] devtmpfs: initialized
[ 0.222986] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.223533] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.223567] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.227388] pinctrl core: initialized pinctrl subsystem
[ 0.229012] NET: Registered protocol family 16
[ 0.232036] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.258277] omap_hwmod: debugss: _wait_target_disable failed
[ 0.322745] cpuidle: using governor ladder
[ 0.334724] cpuidle: using governor menu
[ 0.343099] OMAP GPIO hardware version 0.1
[ 0.349898] GPIO line 112 (MCASP0_AXR0) hogged as output/low
[ 0.362928] No ATAGs?
[ 0.362959] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.363259] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.363273] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.416995] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.421743] vgaarb: loaded
[ 0.422394] SCSI subsystem initialized
[ 0.427217] usbcore: registered new interface driver usbfs
[ 0.427297] usbcore: registered new interface driver hub
[ 0.427415] usbcore: registered new device driver usb
[ 0.428021] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.428082] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.428200] media: Linux media interface: v0.10
[ 0.428269] Linux video capture interface: v2.00
[ 0.428357] pps_core: LinuxPPS API ver. 1 registered
[ 0.428366] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.428392] PTP clock support registered
[ 0.429232] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.430661] NetLabel: Initializing
[ 0.430776] NetLabel: domain hash size = 128
[ 0.430785] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.430876] NetLabel: unlabeled traffic allowed by default
[ 0.431449] clocksource: Switched to clocksource timer1
[ 0.557853] VFS: Disk quotas dquot_6.6.0
[ 0.557986] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.573283] NET: Registered protocol family 2
[ 0.574345] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.574405] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.574468] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.574545] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.574568] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.574779] NET: Registered protocol family 1
[ 0.583739] RPC: Registered named UNIX socket transport module.
[ 0.583761] RPC: Registered udp transport module.
[ 0.583770] RPC: Registered tcp transport module.
[ 0.583777] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.806692] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.809776] audit: initializing netlink subsys (disabled)
[ 0.809884] audit: type=2000 audit(0.740:1): initialized
[ 0.815407] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.815712] zbud: loaded
[ 0.820953] NFS: Registering the id_resolver key type
[ 0.821004] Key type id_resolver registered
[ 0.821013] Key type id_legacy registered
[ 0.821035] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.821450] fuse init (API version 7.26)
[ 0.821892] orangefs_debugfs_init: called with debug mask: :none: :0:
[ 0.822210] orangefs_init: module version upstream loaded
[ 0.822223] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.835843] aufs 4.9-20170612
[ 0.842139] Key type asymmetric registered
[ 0.842164] Asymmetric key parser 'x509' registered
[ 0.842291] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.846602] io scheduler noop registered
[ 0.846619] io scheduler deadline registered
[ 0.846719] io scheduler cfq registered (default)
[ 0.848179] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.848635] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.851975] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.853215] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.856783] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 1.254223] random: fast init done
[ 1.616400] console [ttyS0] enabled
[ 1.621068] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 159, base_baud = 3000000) is a 8250
[ 1.631687] [drm] Initialized
[ 1.638861] libphy: Fixed MDIO Bus: probed
[ 1.644165] tun: Universal TUN/TAP device driver, 1.6
[ 1.649280] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.657314] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.664070] ehci-pci: EHCI PCI platform driver
[ 1.668700] ehci-platform: EHCI generic platform driver
[ 1.674260] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.680104] usbcore: registered new interface driver usb-storage
[ 1.688663] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.712975] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.735088] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.740577] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.748351] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.755211] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.762492] usb usb1: Product: MUSB HDRC host driver
[ 1.767504] usb usb1: Manufacturer: Linux 4.9.34+ musb-hcd
[ 1.773038] usb usb1: SerialNumber: musb-hdrc.1
[ 1.778634] hub 1-0:1.0: USB hub found
[ 1.782586] hub 1-0:1.0: 1 port detected
[ 1.805402] mousedev: PS/2 mouse device common for all mice
[ 1.813437] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.821679] i2c /dev entries driver
[ 1.827038] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.835344] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.843162] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.967109] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.978662] mmc1: new high speed MMC card at address 0001
[ 1.984236] mmc0: new high speed SDHC card at address aaaa
[ 1.995010] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 1.999944] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[ 2.009252] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[ 2.017129] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.023763] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[ 2.033716] mmcblk1: p1 p2 p3 p4 < p5 p6 >
[ 2.049204] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.055611] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.065046] usbcore: registered new interface driver usbhid
[ 2.071005] usbhid: USB HID core driver
[ 2.074958] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 2.083586] ashmem: initialized
[ 2.087329] remoteproc remoteproc0: wkup_m3 is available
[ 2.095235] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 2.102287] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.108011] NET: Registered protocol family 10
[ 2.117997] mip6: Mobile IPv6
[ 2.123829] mmc2: new high speed SDIO card at address 0001
[ 2.131392] NET: Registered protocol family 17
[ 2.136039] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.149248] Key type dns_resolver registered
[ 2.153585] mpls_gso: MPLS GSO support
[ 2.157600] omap_voltage_late_init: Voltage driver support not added
[ 2.164550] PM: Cannot get wkup_m3_ipc handle
[ 2.169143] ThumbEE CPU extension supported.
[ 2.173491] Registering SWP/SWPB emulation handler
[ 2.179496] registered taskstats version 1
[ 2.183777] zswap: loaded using pool lzo/zbud
[ 2.188246] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 2.225575] Key type encrypted registered
[ 2.272823] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 2.284229] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 2.290127] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.297146] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.304721] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.312345] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.319731] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.327038] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 2.334119] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 2.341164] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 2.348458] remoteproc remoteproc0: powering up wkup_m3
[ 2.348475] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 2.348726] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 2.348748] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 2.376297] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.383566] usb 1-1: Product: USB2.0 Hub
[ 2.388926] hub 1-1:1.0: USB hub found
[ 2.393214] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,GW1A,BBGW16052080'
[ 2.400530] hub 1-1:1.0: 4 ports detected
[ 2.404907] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 2.440565] bone_capemgr bone_capemgr: slot #0: No cape found
[ 2.471879] bone_capemgr bone_capemgr: slot #1: No cape found
[ 2.504843] bone_capemgr bone_capemgr: slot #2: No cape found
[ 2.535936] bone_capemgr bone_capemgr: slot #3: No cape found
[ 2.541850] bone_capemgr bone_capemgr: initialized OK.
[ 2.552318] PM: bootloader does not support rtc-only!
[ 2.558536] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.567470] of_cfs_init
[ 2.570088] of_cfs_init: OK
[ 2.573640] wlan-en-regulator: disabling
[ 2.584382] Freeing unused kernel memory: 4096K (c1100000 - c1500000)
starting version 230
[INFO] Flasher detected. Avoiding expand partition mechanism.
[ 4.887017] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[INFO] Flasher detected. Avoiding persistent machine-id.
[ 5.343104] systemd[1]: System time before build time, advancing clock.
[ 5.445417] systemd[1]: systemd 230 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 5.464669] systemd[1]: Detected architecture arm.
Welcome to Resin OS 2.4.2+rev1!
[ 5.489728] systemd[1]: Set hostname to <beaglebone>.
[ 5.509694] systemd[1]: Initializing machine ID from random generator.
[ 5.516929] systemd[1]: Installed transient /etc/machine-id file.
[ 5.531684] systemd[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 5.539696] systemd[1]: Set hardware watchdog to 10s.
[ 6.123793] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.144320] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 6.160663] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Socket.
Mounting Debug File System...
Mounting POSIX Message Queue File System...
Starting Apply Kernel Variables...
Mounting Configuration File System...
Starting Remount Root and Kernel File Systems...
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Listening on udev Control Socket.
Starting Setup Virtual Console...
Starting Create list of required st... nodes for the current kernel...
[ OK ] Created slice User and Session Slice.
[ 6.587002] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Reached target Slices.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on udev Kernel Socket.
Mounting FUSE Control File System...
[ OK ] Reached target Swap.
Mounting Temporary Directory...
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Configuration File System.
[ OK ] Mounted Debug File System.
[ OK ] Mounted Temporary Directory.
[ OK ] Started Journal Service.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
Starting Bind mount volatile /var/lib...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Bind mount volatile /var/lib.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Tell Plymouth To Write Out Runtime Data...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Create Volatile Files and Directories.
Mounting Dropbear Host Key Mount Point...
Mounting NetworkManager system connections bind mount...
Mounting ResinOS hostname...
Starting Update UTMP about System Boot/Shutdown...
Mounting OpenSSL random state bind mount...
[ OK ] Mounted NetworkManager system connections bind mount.
[ OK ] Mounted Dropbear Host Key Mount Point.
[ OK ] Mounted ResinOS hostname.
[ OK ] Mounted OpenSSL random state bind mount.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started udev Coldplug all Devices.
Starting udev Wait for Complete Device Initialization...
[ OK ] Found device /dev/ttyS0.
[ OK ] Found device /dev/disk/by-label/flash-boot.
Mounting Flasher boot partition mountpoint...
[ 10.351216] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ OK ] Mounted Flasher boot partition mountpoint.
Starting Temporary resin config in /tmp/conf...
[ OK ] Started Temporary resin config in /tmp/conf.
Mounting Flasher conf partition mountpoint...
[ OK ] Mounted Flasher conf partition mountpoint.
Starting Resin NTP configuration service...
[ OK ] Started Resin NTP configuration service.
Starting Network Time Synchronization...
[ OK ] Started Network Time Synchronization.
[ 11.396241] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ OK ] Reached target System Time Synchronized.
[ 11.573023] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 11.605021] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 12.016214] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 12.056985] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
[ OK ] Listening on Load/Save RF Kill Switch Status [ 12.082088] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
/dev/rfkill Watch.
[ 12.216356] remoteproc remoteproc1: 4a334000.pru0 is available
[ 12.231861] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a334000 probed successfully
[ 12.268725] remoteproc remoteproc2: 4a338000.pru1 is available
[ 12.290813] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a338000 probed successfully
[ 12.507299] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl18xx-conf.bin failed with error -2
[ 12.527688] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
[ 12.548407] wlcore: WARNING falling back to default config
[ OK ] Started udev Wait for Complete Device Initialization.
Starting Show Plymouth Boot Screen...
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
Resin OS 2.4.2 541db86 ttyS0
541db86 login:
541db86 login: [ 167.079456] wlan0: deauthenticating from f0:9f:c2:34:4a:93 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 167.548248] wlcore: down
[ 168.427115] systemd-shutdow: 28 output lines suppressed due to ratelimiting
[ 168.449210] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 168.475085] systemd-journald[274]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 168.493172] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 168.513874] systemd-shutdown[1]: Process 389 (plymouthd) has been been marked to be excluded from killing. It is running from the root file system, and thus likely to block re-mounting of the root file system to read-only. Please consider moving it into an initrd file system instead.
[ 168.542691] systemd-shutdown[1]: Unmounting file systems.
[ 168.549879] systemd-shutdown[1]: Remounting '/mnt/boot' read-only with options 'fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro'.
[ 168.571403] systemd-shutdown[1]: Unmounting /mnt/boot.
[ 168.589864] systemd-shutdown[1]: Remounting '/mnt/bootorig' read-only with options 'fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro'.
[ 168.606624] systemd-shutdown[1]: Unmounting /mnt/bootorig.
[ 168.622244] systemd-shutdown[1]: Remounting '/tmp' read-only with options ''.
[ 168.630522] systemd-shutdown[1]: Unmounting /tmp.
[ 168.651080] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 168.659536] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 168.666815] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 168.716627] reboot: Power down
[ 168.719945] System will go to power_off state in approx. 1 second
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
cpsw, usb_ether
Card did not respond to voltage select!
** Bad device mmc 0 **
** Unable to read file resin-image-flasher **
reading resin-image
MMC Device 2 not found
** Bad device mmc 2 **
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
Found resin image on mmc 1
Loading resinOS_uEnv.txt from mmc device 1 partition 1
mmc1(part 0) is current device
SD/MMC found on device 1
reading boot.scr
reading uEnv.txt
22 bytes read in 4 ms (4.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
12257576 bytes read in 1000 ms (11.7 MiB/s)
58499 bytes read in 45 ms (1.2 MiB/s)
Starting kernel ...
