Hi is it possible to use a Pi Juice or some other sort of UPS with the BalenaFin ? can it be powered via the 5v pins on the 40 pin header ?
Hi @alinnz, you can use the PiJuice or any UPS that is compatible with the Raspberry Pi HAT standard. The balenaFin can be powered from the 5v pins in the 40-pin HAT header.
Cheers,
Nico.
