Anyone seeing fetcher errors with the balena package when attempting to build BalenaOS v2.47.1+rev2? I’ve been seeing this over the last couple of days.
Here is the bitbake output:
$ bitbake resin-image-flasher
WARNING: Layer balena-beaglebone should set LAYERSERIES_COMPAT_balena-beaglebone in its conf/layer.conf file to list the core layer names it is compatible with.
Loading cache: 100% |#######################################################################################################################################| Time: 0:00:01
Loaded 3414 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.40.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "beaglebone-green-wifi"
DISTRO = "balena-os"
DISTRO_VERSION = "2.47.1"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta
meta-poky = "HEAD:cb26830f765f03309c0663352cc5849491271be8"
meta-oe
meta-filesystems
meta-networking
meta-python = "HEAD:2d088d252624b19df384aecc434d23afb636178f"
meta-ti = "HEAD:727411f95ef1f66034beac08702f21b30a1b84c9"
meta-balena-common
meta-balena-thud = "HEAD:c6a9c9490c1ef8ef854b4afc96d4fcfae0c9928b"
meta-balena-beaglebone = "HEAD:a6efdd49f84c0e4e143251e94dba0b46eba2c852"
meta-rust = "HEAD:c5ff05d1e99c1e80844c1673456e2368499918c7"
Initialising tasks: 100% |##################################################################################################################################| Time: 0:00:05
Sstate summary: Wanted 793 Found 0 Missed 793 Current 597 (0% match, 42% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: balena-18.09.10-dev+git7cb464a406748016f2df0c31a9851d20456a3d31-r0 do_fetch: Failed to fetch URL git://github.com/resin-os/balena.git;branch=master;destsuffix=git/src/import, attempting MIRRORS if available
WARNING: bindmount-0.0.1.AUTOINC+f597fb0266-r0 do_fetch: Failed to fetch URL git://git@github.com/resin-os/resinos-bindmount.git;protocol=ssh, attempting MIRRORS if available
ERROR: balena-18.09.10-dev+git7cb464a406748016f2df0c31a9851d20456a3d31-r0 do_fetch: Fetcher failure: Unable to find revision 7cb464a406748016f2df0c31a9851d20456a3d31 in branch master even from upstream
ERROR: balena-18.09.10-dev+git7cb464a406748016f2df0c31a9851d20456a3d31-r0 do_fetch: Fetcher failure for URL: 'git://github.com/resin-os/balena.git;branch=master;destsuffix=git/src/import'. Unable to fetch URL from any source.
ERROR: balena-18.09.10-dev+git7cb464a406748016f2df0c31a9851d20456a3d31-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/eric/workspace/balena-beaglebone/build/tmp/work/armv7at2hf-neon-poky-linux-gnueabi/balena/18.09.10-dev+git7cb464a406748016f2df0c31a9851d20456a3d31-r0/temp/log.do_fetch.9449
ERROR: Task (/home/eric/workspace/balena-beaglebone/build/../layers/meta-balena/meta-balena-common/recipes-containers/balena/balena_git.bb:do_fetch) failed with exit code '1'
I’ve seen this with both Ubuntu 16.04 and 18.04 build machines. Here’s how I’ve been setting up my workspace and kicking off the build:
sudo apt-get update
sudo apt-get install apt-transport-https ca-certificates curl \
gnupg-agent software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository \
"deb [arch=amd64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) stable"
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io
# add the docker user group and add the standard user
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp docker
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping python3-git python3-jinja2 \
libegl1-mesa libsdl1.2-dev pylint3 xterm
sudo apt-get install npm jq
mkdir ~/workspace; cd ~/workspace/
git clone https://github.com/balena-os/balena-beaglebone
cd balena-beaglebone
git submodule update --init --recursive
git checkout v2.47.1+rev2 --recurse-submodules
./balena-yocto-scripts/build/barys -d --dry-run
source layers/poky/oe-init-build-env
# <edit build/conf/local.conf, enable the beaglebone-green-wireless machine, debug image, and image compression>
Any input would be super helpful. I have been able to clone the balena repository and checkout the tag which the fetcher says it cannot find.
