Hello! i am trying to set up Balena OS on my Pi zero. the flash and initial setup went well. However when i attempt to add variabled to the host config either via the dashboard or directly, BalenaOS will not connect back to the VPN. The ACT light is solid green. The config i am changing is fr the /boot/config.txt for my screen. The site with the listed changes is directly below.
https://www.waveshare.com/wiki/7inch_LCD_for_Pi
I have also copied the logs below from the dashboard
05.03.21 01:46:33 (-0500) Supervisor starting
05.03.21 01:46:49 (-0500) Applying configuration change {“SUPERVISOR_POLL_INTERVAL”:“900000”,“SUPERVISOR_DELTA_VERSION”:“3”}
05.03.21 01:46:53 (-0500) Applied configuration change {“SUPERVISOR_POLL_INTERVAL”:“900000”,“SUPERVISOR_DELTA_VERSION”:“3”}
05.03.21 01:46:55 (-0500) Creating network ‘default’
05.03.21 01:56:18 (-0500) Supervisor starting
05.03.21 01:56:24 (-0500) Applying configuration change {“SUPERVISOR_DELTA”:“1”}
05.03.21 01:56:24 (-0500) Applied configuration change {“SUPERVISOR_DELTA”:“1”}
05.03.21 02:10:00 (-0500) Supervisor starting
05.03.21 11:59:45 (-0500) Rebooting
05.03.21 12:02:37 (-0500) Supervisor starting
05.03.21 12:25:04 (-0500) Applying boot config: {“disable_splash”:“1”,“dtoverlay”:[“dpi24”],“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=on”],“enable_uart”:“1”,“gpu_mem”:“16”}
05.03.21 12:25:06 (-0500) Applied boo
