BalenaOS on reComputer R1142
I’m following the guide for setting up balenaOS on the reComputer R1000 ((reComputer R1000 with balena | Seeed Studio Wiki)), but I’m running into an issue at Step 3: Configure. The device doesn’t appear in the balenaCloud environment.
I suspect this might be because I’m using a reComputer R1142 (R1100 series) instead of the R1000 model referenced in the guide.
Is there a dedicated step-by-step guide for the R1100 series? If not, could you please point me in the right direction?
Thanks in advance!
Fixed: Faulty Ethernet cable…
@Lennard first of all welcome to the balena community!
is the reComputer R1142 working properly on balena?
Let us know how we can help you more!
@mpous The reComputer appears to be working correctly with balenaCloud. My only concern is that I followed the R100x setup guide, while my actual device is an R110x. I’m worried this mismatch might cause issues down the line.
What would be the proper way to update or adjust my setup to align with the R110x specifications?
Let me know if you want to tweak it further always happy to refine!
To be honest @Lennard i’m not sure what are the differences between the R100x and the R110x.
Are there any dtoverlays or drivers that are different that need to be added?
