i´m using BalenaOS with Raspberry Pi 3 B+.
I want to setup a GSM connection via NetworkManager. What I did is using the Tutorial form Balena to do it. The GSM Modem shows as connected and gets an IP but the problem is, its not in the dashboard as online nor can I ping sites if I connect via LAN to the device. So there is no Internet available on the device.
nmcli shows
ttyUSB1: connected to balena-cellular
"Huawei E220 / E230/E270/E870 HSDPA/HSUPA"
gsm (option1), hw, iface ppp0, mtu 1500
inet4 100.83.184.31/32
route4 10.64.64.64/32
route4 0.0.0.0/0
wlan0: connected to balena-hotspot1
"Broadcom Wi-Fi"
wifi (brcmfmac), XXX, hw, mtu 1500
inet4 192.168.125.1/24
route4 192.168.125.0/24
route4 0.0.0.0/0
inet6 fe80::ba27:ebff:fea6:76b7/64
route6 ff00::/8
route6 fe80::/64
supervisor0: connected to supervisor0
"supervisor0"
bridge, XXX, sw, mtu 1500
inet4 172.17.0.1/16
route4 172.17.0.0/16
ppp0: disconnected
"ppp0"
ppp, sw, mtu 1500
root@XXX:~# mmcli -m 0
/org/freedesktop/ModemManager1/Modem/0 (device id '95ebf7e8923f07d4e525624b04ab9f6ef582a1d1')
Hardware | manufacturer: 'huawei'
| model: 'E17X'
| revision: '11.304.19.20.00'
| H/W revision: 'unknown'
| supported: 'gsm-umts'
| current: 'gsm-umts'
| equipment id: 'XXX'
System | device: '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3'
| drivers: 'option1'
| plugin: 'Huawei'
| primary port: 'ttyUSB1'
| ports: 'ttyUSB0 (at), ttyUSB1 (at)'
Numbers | own : 'unknown'
Status | lock: 'none'
| unlock retries: 'sim-pin (3), sim-pin2 (3), sim-puk (10), sim-puk2 (10)'
| state: 'connected'
| power state: 'on'
| access tech: 'umts'
| signal quality: '38' (recent)
Modes | supported: 'allowed: 2g, 3g; preferred: none
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g; preferred: none
| allowed: 3g; preferred: none'
| current: 'allowed: 2g, 3g; preferred: none'
Bands | supported: 'unknown'
| current: 'unknown'
IP | supported: 'ipv4'
3GPP | imei: 'XXX'
| enabled locks: 'none'
| operator id: '26202'
| operator name: 'klarmobil'
| subscription: 'unknown'
| registration: 'home'
| EPS UE mode: 'unknown'
SIM | path: '/org/freedesktop/ModemManager1/SIM/0'
Bearers | paths: '/org/freedesktop/ModemManager1/Bearer/0'
The NetworkManager Config
[connection]
id=balena-cellular
type=gsm
autoconnect=true
[gsm]
apn=web.vodafone.de
number=*99#
[serial]
baud=115200
[ipv4]
dns=8.8.8.8;
dns-search=
ignore-auto-dns=true
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
Thanks for your help!
