i manged to build docker image for balena-fin-flash-coprocessor. But when running docker
i get error:
root@raspberrypi:/home/pi# docker run flash
/usr/src/app/node_modules/node-gtk/lib/index.js:489
GI.Repository_require.call(repo, ns, version || null, 0)
Error: Typelib file for namespace ‘Fin’, version ‘0.1’ not found
at Object.giRequire [as require] (/usr/src/app/node_modules/node-gtk/lib/index.js:489:27)
at Object. (/usr/src/app/index.js:5:10)
at Module._compile (internal/modules/cjs/loader.js:1137:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1157:10)
at Module.load (internal/modules/cjs/loader.js:985:32)
at Function.Module._load (internal/modules/cjs/loader.js:878:14)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
at internal/main/run_main_module.js:17:47
I am using rabian fin lite image on balena fin. So is it possible to use rasbian and build images on docker and run them? If that is not possible i have to use manual flashing with jtagger right? Is there step by step instructions how to that?
-Olli
