BalenaDash Redirecting to home page not showing launch_url webpage defined
I deployed on raspberry pi4, by clicking deploy with balena button. flashed the image booted but i only see the balena logo on my monitor
Screenshot 2021-09-24 12_19_40-balena dashboard _ cheeky-wildflower
nothing on the forums search had works since looks to be from 2019 or 2020.
I’m in the exact same situation as you, tried the install and every guide, post, etc. since 2020.
I did try it on a Raspberry PI 3 64bit to see and it works perfectly fine.
So it’s only with the Raspberry PI 4 than I got this permanent balena logo.
Hello @amoges and @jorgesea yes! i had similar experience! I’m going to open an issue on balena-dash project.
Meanwhile if you only need to visualize a website, did you try to deploy GitHub - balenablocks/browser: A drop-in web browser block ?
Let me know if that works good!
BTW I just created the github issue here if you would like to add anything
Please try deploying balena-dash to your fleets again as a fix has been added for this issue.
Thanks - Mark
