I was hoping someone could help me understand what is going wrong with an balena device of ours. Somehow the devices suddenly restarts itselfs which is causing us trouble.
2023-08-05T16:15:28.085969+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:28 2023 Connection reset, restarting [0]
2023-08-05T16:15:28.086529+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:28 2023 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.84.126 52.4.252.97 restart
2023-08-05T16:15:28.093819+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:28.094460+0000 13727ba5a2d9 balena-supervisor[2334]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:28.094818+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:28 2023 SIGUSR1[soft,connection-reset] received, process restarting
2023-08-05T16:15:28.094818+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:28 2023 Restart pause, 5 second(s)
2023-08-05T16:15:28.784091+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[47me[30mapie[39me[49m] GET /v1/device 200 - 8.878 ms
2023-08-05T16:15:28.784215+0000 13727ba5a2d9 balena-supervisor[2334]: [e[47me[30mapie[39me[49m] GET /v1/device 200 - 8.878 ms
2023-08-05T16:15:32.769488+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[47me[30mapie[39me[49m] GET /v1/healthy 200 - 0.726 ms
2023-08-05T16:15:32.771129+0000 13727ba5a2d9 balena-supervisor[2334]: [e[47me[30mapie[39me[49m] GET /v1/healthy 200 - 0.726 ms
2023-08-05T16:15:33.094715+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:33 2023 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2023-08-05T16:15:33.095249+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:33 2023 TCP/UDP: Preserving recently used remote address: [AF_INET]52.7.228.224:443
2023-08-05T16:15:33.095249+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:33 2023 Socket Buffers: R=[131072->131072] S=[16384->16384]
2023-08-05T16:15:33.095249+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:33 2023 Attempting to establish TCP connection with [AF_INET]52.7.228.224:443 [nonblock]
2023-08-05T16:15:34.095266+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 TCP connection established with [AF_INET]52.7.228.224:443
2023-08-05T16:15:34.095266+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 Socket flags: TCP_NODELAY=1 succeeded
2023-08-05T16:15:34.095862+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 TCP_CLIENT link local: (not bound)
2023-08-05T16:15:34.095862+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 TCP_CLIENT link remote: [AF_INET]52.7.228.224:443
2023-08-05T16:15:34.193645+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 TLS: Initial packet from [AF_INET]52.7.228.224:443, sid=52bf7a6f 53458ccf
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 VERIFY OK: depth=1, C=US, ST=WA, L=Seattle, O=balena.io, OU=balenaCloud, CN=open-balena-vpn-rootCA
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 VERIFY KU OK
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 Validating certificate extended key usage
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 VERIFY EKU OK
2023-08-05T16:15:34.293717+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 VERIFY OK: depth=0, C=US, ST=WA, L=Seattle, O=balena.io, OU=balenaCloud, CN=vpn.balena-cloud.com
2023-08-05T16:15:34.417140+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 2048 bit RSA
2023-08-05T16:15:34.417140+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:34 2023 [vpn.balena-cloud.com] Peer Connection Initiated with [AF_INET]52.7.228.224:443
2023-08-05T16:15:35.436966+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 SENT CONTROL [vpn.balena-cloud.com]: 'PUSH_REQUEST' (status=1)
2023-08-05T16:15:35.536213+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 PUSH: Received control message: 'PUSH_REPLY,ping 10,ping-exit 60,sndbuf 0,rcvbuf 0,route 52.4.252.97,socket-flags TCP_NODELAY,ifconfig 10.241.13.48 52.4.252.97,peer-id 1310,cipher AES-128-GCM'
2023-08-05T16:15:35.536288+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: timers and/or timeouts modified
2023-08-05T16:15:35.536288+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Socket Buffers: R=[131072->131072] S=[46080->46080]
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: --socket-flags option modified
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Socket flags: TCP_NODELAY=1 succeeded
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: --ifconfig/up options modified
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: route options modified
2023-08-05T16:15:35.536332+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: peer-id set
2023-08-05T16:15:35.536435+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: adjusting link_mtu to 1627
2023-08-05T16:15:35.536435+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 OPTIONS IMPORT: data channel crypto options modified
2023-08-05T16:15:35.536435+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Data Channel: using negotiated cipher 'AES-128-GCM'
2023-08-05T16:15:35.536488+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Outgoing Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
2023-08-05T16:15:35.536488+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Incoming Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
2023-08-05T16:15:35.536488+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Preserving previous TUN/TAP instance: resin-vpn
2023-08-05T16:15:35.536488+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 /etc/openvpn-misc/upscript.sh resin-vpn 1500 1555 10.240.84.126 52.4.252.97 restart
2023-08-05T16:15:35.539706+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.539979+0000 13727ba5a2d9 balena-supervisor[2334]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.540452+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.540531+0000 13727ba5a2d9 balena-supervisor[2334]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.541398+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.541429+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.541557+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 NOTE: Pulled options changed on restart, will need to close and reopen TUN/TAP device.
2023-08-05T16:15:35.541557+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Closing TUN/TAP interface
2023-08-05T16:15:35.541557+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 /sbin/ip addr del dev resin-vpn local 10.240.84.126 peer 52.4.252.97
2023-08-05T16:15:35.541619+0000 13727ba5a2d9 balena-supervisor[2334]: [e[34minfoe[39m] VPN connection is active.
2023-08-05T16:15:35.542652+0000 13727ba5a2d9 openvpn[2176928]: ip: RTNETLINK answers: Operation not permitted
2023-08-05T16:15:35.543017+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 Linux ip addr del failed: external program exited with error status: 2
2023-08-05T16:15:35.554141+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:35 2023 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.84.126 52.4.252.97 init
2023-08-05T16:15:35.557200+0000 13727ba5a2d9 3c60309dfe5b[1067]: [e[34minfoe[39m] VPN connection is not active.
2023-08-05T16:15:35.557328+0000 13727ba5a2d9 balena-supervisor[2334]: [e[34minfoe[39m] VPN connection is not active.
2023-08-05T16:15:36.557417+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:36 2023 ROUTE_GATEWAY 192.168.50.1/255.255.255.0 IFACE=wlan0 HWADDR=a0:e7:0b:7e:9b:95
2023-08-05T16:15:36.557718+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:36 2023 ERROR: Cannot ioctl TUNSETIFF resin-vpn: Operation not permitted (errno=1)
2023-08-05T16:15:36.557718+0000 13727ba5a2d9 openvpn[1177214]: Sat Aug 5 16:15:36 2023 Exiting due to fatal error
2023-08-05T16:15:36.558334+0000 13727ba5a2d9 systemd[1]: openvpn.service: Main process exited, code=exited, status=1/FAILURE
Device info
Can anyone tell me why this is happening and how to fix this?
Thanks.
