hi, i’m using Windows 10. i spent a whole lot of time yesterday in trying to get balena ssh <uuid> to work for device . to no avail; i get:
g_[username]@ssh.balena-devices.com: Permission denied (publickey).
balena devices and balena device <short-uuid> work. balena <local_ip> works. i can putty to the public device name <uuiid>.balena-devices.com:22. i can putty to <local_ip>:22222, but all for the host OS only. i’ve generated an ssh key on my laptop and added it to balena’s keys online. i’ve also added it to a file in the host OS (ugh, i can’t remember the name of it now). i’ve set DEBUG = 1 on my laptop:
set DEBUG = 1
C:\Users\mahes>balena devices
[debug] original argv0="C:\Program Files\balena-cli\bin\\..\client\bin\node.exe" argv=[C:\Program Files\balena-cli\client\bin\node.exe,C:\Program Files\balena-cli\client\bin\run,devices] length=3
ID UUID DEVICE NAME DEVICE TYPE APPLICATION NAME STATUS IS ONLINE SUPERVISOR VERSION OS VERSION DASHBOARD URL
<id> <short-uuid> <some-words> raspberry-pi <myAppName> Idle false 9.14.0 balenaOS 2.32.0+rev1 https://dashboard.balena-cloud.com/devices/<full-uuid>/summary
<id2> <short-uuid> <other-words> raspberry-pi <myAppName> Idle true 9.14.0 balenaOS 2.32.0+rev1 https://dashboard.balena-cloud.com/devices/<full-uuid>/summary
here’s the full output (--verbose) of trying to connect using balena ssh:
C:\Users\[user]>balena ssh [short-uuid] --verbose
[debug] original argv0="C:\Program Files\balena-cli\bin\\..\client\bin\node.exe" argv=[C:\Program Files\balena-cli\client\bin\node.exe,C:\Program Files\balena-cli\client\bin\run,ssh,[short-uuid],--verbose] length=5
[Debug] Fetching application by name [short-uuid] (string)
[Debug] Application not found
[Debug] Fetching device by UUID [short-uuid] (string)
OpenSSH_for_Windows_7.7p1, LibreSSL 2.6.5
debug3: Failed to open file:C:/Users/[user]/.ssh/config error:2
debug3: Failed to open file:C:/ProgramData/ssh/ssh_config error:2
debug2: resolving "ssh.balena-devices.com" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to ssh.balena-devices.com [54.147.226.224] port 22.
debug1: Connection established.
debug3: Failed to open file:C:/Users/[user]/.ssh/id_rsa error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_rsa.pub error:2
debug1: key_load_public: No such file or directory
debug1: identity file C:\\Users\\[user]/.ssh/id_rsa type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_rsa-cert error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_rsa-cert.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_rsa-cert type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_dsa error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_dsa.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_dsa type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_dsa-cert error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_dsa-cert.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_dsa-cert type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ecdsa error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ecdsa.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_ecdsa type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ecdsa-cert error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ecdsa-cert.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_ecdsa-cert type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ed25519 error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ed25519.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_ed25519 type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ed25519-cert error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_ed25519-cert.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_ed25519-cert type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_xmss error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_xmss.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_xmss type -1
debug3: Failed to open file:C:/Users/[user]/.ssh/id_xmss-cert error:2
debug3: Failed to open file:C:/Users/[user]/.ssh/id_xmss-cert.pub error:2
debug1: identity file C:\\Users\\[user]/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_for_Windows_7.7
debug1: Remote protocol version 2.0, remote software version Go
debug1: no match: Go
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to ssh.balena-devices.com:22 as 'g_[user]h'
debug3: hostkeys_foreach: reading file "/dev/null"
debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts error:2
debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts2 error:2
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none
debug2: compression stoc: none
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-ed25519,ssh-rsa,ecdsa-sha2-nistp256,ssh-dss
debug2: ciphers ctos: aes128-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr
debug2: ciphers stoc: aes128-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr
debug2: MACs ctos: hmac-sha2-256-etm@openssh.com,hmac-sha2-256,hmac-sha1,hmac-sha1-96
debug2: MACs stoc: hmac-sha2-256-etm@openssh.com,hmac-sha2-256,hmac-sha1,hmac-sha1-96
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:g6EWPpcXbcBHTxrPdYezd+9YFd//GPJKiNC8f1ryaaI
Warning: Permanently added 'ssh.balena-devices.com,54.147.226.224' (ECDSA) to the list of known hosts.
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug3: unable to connect to pipe \\\\.\\pipe\\openssh-ssh-agent, error: 2
debug1: pubkey_prepare: ssh_get_authentication_socket: No such file or directory
debug2: key: C:\\Users\\[user]/.ssh/id_rsa (0000000000000000)
debug2: key: C:\\Users\\[user]/.ssh/id_dsa (0000000000000000)
debug2: key: C:\\Users\\[user]/.ssh/id_ecdsa (0000000000000000)
debug2: key: C:\\Users\\[user]/.ssh/id_ed25519 (0000000000000000)
debug2: key: C:\\Users\\[user]/.ssh/id_xmss (0000000000000000)
debug3: send packet: type 5
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey
debug3: start over, passed a different list publickey
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: C:\\Users\\[user]/.ssh/id_rsa
debug3: no such identity: C:\\Users\\[user]/.ssh/id_rsa: No such file or directory
debug1: Trying private key: C:\\Users\\[user]/.ssh/id_dsa
debug3: no such identity: C:\\Users\\[user]/.ssh/id_dsa: No such file or directory
debug1: Trying private key: C:\\Users\\[user]/.ssh/id_ecdsa
debug3: no such identity: C:\\Users\\[user]/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: C:\\Users\\[user]/.ssh/id_ed25519
debug3: no such identity: C:\\Users\\[user]/.ssh/id_ed25519: No such file or directory
debug1: Trying private key: C:\\Users\\[user]/.ssh/id_xmss
debug3: no such identity: C:\\Users\\[user]/.ssh/id_xmss: No such file or directory
debug2: we did not send a packet, disable method
debug1: No more authentication methods to try.
g_[user]h@ssh.balena-devices.com: Permission denied (publickey).
C:\Users\[user]>
