When I try either Bluetooth or AirPlay I get no sound. Logs are attached. Perhaps I haven’t configured something correctly? It looks like SBC decoding error is an issue? How do I fix that?
Similar problem with AirPlay.
Bluetooth logs
16.07.20 21:11:07 (+0000) Installing service 'bluetooth-audio sha256:e62c06918fd63940ed5ae16177226a37770e455f15fed27849a253f3f5d3757c'
16.07.20 21:11:07 (+0000) Installed service 'bluetooth-audio sha256:e62c06918fd63940ed5ae16177226a37770e455f15fed27849a253f3f5d3757c'
16.07.20 21:11:07 (+0000) Starting service 'bluetooth-audio sha256:e62c06918fd63940ed5ae16177226a37770e455f15fed27849a253f3f5d3757c'
16.07.20 21:11:16 (+0000) Started service 'bluetooth-audio sha256:e62c06918fd63940ed5ae16177226a37770e455f15fed27849a253f3f5d3757c'
16.07.20 21:11:18 (+0000) <bluetooth-audio> Setting output volume to 75%
16.07.20 21:11:19 (+0000) <bluetooth-audio> Connection notify volume is 75%
16.07.20 21:11:19 (+0000) <bluetooth-audio> amixer: Unable to find simple control 'PCM',0
16.07.20 21:11:19 (+0000) <bluetooth-audio> amixer: Unable to find simple control 'Digital',0
16.07.20 21:11:20 (+0000) <bluetooth-audio> Restarting bluetooth service
16.07.20 21:11:27 (+0000) <bluetooth-audio> Starting bluetooth agent in Secure Simple Pairing Mode (SSPM) - No PIN code provided or invalid
16.07.20 21:11:28 (+0000) <bluetooth-audio> Bluetooth agent registered
16.07.20 21:11:31 (+0000) <bluetooth-audio> Device is discoverable as "AirPi"
16.07.20 21:13:51 (+0000) <bluetooth-audio> Setting output volume to 75%
16.07.20 21:13:52 (+0000) <bluetooth-audio> Connection notify volume is 75%
16.07.20 21:13:52 (+0000) <bluetooth-audio> amixer: Unable to find simple control 'PCM',0
16.07.20 21:13:52 (+0000) <bluetooth-audio> amixer: Unable to find simple control 'Digital',0
16.07.20 21:13:52 (+0000) <bluetooth-audio> Restarting bluetooth service
16.07.20 21:13:57 (+0000) <bluetooth-audio> Bluetooth agent registered
16.07.20 21:13:58 (+0000) <bluetooth-audio> Starting bluetooth agent in Secure Simple Pairing Mode (SSPM) - No PIN code provided or invalid
16.07.20 21:14:02 (+0000) <bluetooth-audio> Device is discoverable as "AirPi"
16.07.20 21:15:18 (+0000) <bluetooth-audio> AuthorizeService (/org/bluez/hci0/dev_60_8B_0E_66_11_9F, 0000110d-0000-1000-8000-00805f9b34fb)
16.07.20 21:15:19 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:19 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 17 != 16
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 73 != 72
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 90 != 87
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 110 != 109
16.07.20 21:15:20 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 113 != 112
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 127 != 125
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 130 != 129
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 141 != 140
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 145 != 143
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 151 != 148
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 181 != 178
16.07.20 21:15:21 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 191 != 190
16.07.20 21:15:22 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:22 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 209 != 208
16.07.20 21:15:22 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 213 != 211
16.07.20 21:15:22 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:22 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 226 != 222
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 290 != 289
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 292 != 291
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 309 != 308
16.07.20 21:15:23 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 313 != 311
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 351 != 349
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 367 != 366
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 372 != 370
16.07.20 21:15:24 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 396 != 394
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 405 != 404
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 431 != 430
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 434 != 433
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 444 != 440
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 455 != 451
16.07.20 21:15:25 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 458 != 456
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 474 != 473
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 484 != 483
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 490 != 486
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 495 != 493
16.07.20 21:15:26 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 510 != 508
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 562 != 558
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 572 != 571
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 582 != 580
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 586 != 584
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 589 != 587
16.07.20 21:15:27 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 593 != 591
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 607 != 606
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 625 != 623
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 628 != 627
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 645 != 644
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 660 != 659
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 668 != 666
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:28 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 673 != 672
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 677 != 675
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 701 != 697
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 732 != 729
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:29 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 738 != 736
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 746 != 745
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 761 != 759
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 773 != 772
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 777 != 775
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 805 != 804
16.07.20 21:15:30 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 809 != 807
16.07.20 21:15:32 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such process
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1037 != 1036
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1046 != 1044
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1050 != 1047
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1061 != 1059
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1074 != 1072
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1077 != 1076
16.07.20 21:15:34 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1081 != 1079
16.07.20 21:15:35 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:35 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1095 != 1093
16.07.20 21:15:35 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1154 != 1152
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: SBC decoding error: No such file or directory
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1159 != 1157
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1167 != 1164
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1170 != 1168
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1174 != 1173
16.07.20 21:15:36 (+0000) <bluetooth-audio> /usr/bin/bluealsa: Missing RTP packet: 1202 != 1201
