Balena Sound on Pi Zero W Services Not Showing Up
Thanks for the update. For diagnosis purposes, can you tell us if you were attempting to use AirPlay or Spotify for streaming?
Best regards,
John
Primarily Airplay. Was building it for my in laws, they all use iTunes.
thanks for the update and for not giving up completely. If the app is not downloading it may be because its build has not finished yet or has failed. You can check the build status in the “Releases” tab in the application dashboard. You should also be seeing different values in “Current release” and “Target release” of your device - this is the trigger to start the download. When you come back to this, please have an eye on that and let us know in case the build fails or in case the download does not start even though the current and target releases are different.
