Right - the diagnostics are great and do indicate errors consistent with the errors seen and more:
Supervisor is NOT running (unmatched local and remote Supervisor versions)
Container engine balena is NOT running
Some networking issues detected:
test_dockerhub: Could not query Docker Hub
test_balena_registry: Could not communicate with registry2.balena-cloud.com for authentication
Running the diagnostics also seems to have fixed the underlying issue whatever it was by rebooting the system.
output of journalctl -u balena.service -t balenad --no-pager:
root@14d8bd6:~# journalctl -u balena.service -t balenad --no-pager
-- Logs begin at Sat 2020-04-25 18:37:56 UTC, end at Fri 2020-05-08 21:21:12 UTC. --
May 08 20:47:25 14d8bd6 balenad[858]: time="2020-05-08T20:47:25Z" level=warning msg="Running experimental build"
May 08 20:47:25 14d8bd6 balenad[858]: time="2020-05-08T20:47:25.755794273Z" level=info msg="libcontainerd: started new balena-engine-containerd process" pid=897
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="starting containerd" module=containerd revision= version=1.0.0+unknown
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="setting subreaper..." module=containerd
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="changing OOM score to -500" module=containerd
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." module=containerd type=io.containerd.content.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." module=containerd type=io.containerd.snapshotter.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." module=containerd type=io.containerd.metadata.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." module=containerd type=io.containerd.differ.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." module=containerd type=io.containerd.gc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." module=containerd type=io.containerd.monitor.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." module=containerd type=io.containerd.runtime.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." module=containerd type=io.containerd.grpc.v1
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd-debug.sock module=containerd/debug
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock module=containerd/grpc
May 08 20:47:27 14d8bd6 balenad[858]: time="2020-05-08T20:47:27Z" level=info msg="containerd successfully booted in 0.257754s" module=containerd
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.039115432Z" level=info msg="Graph migration to content-addressability took 0.00 seconds"
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.064902409Z" level=warning msg="Your kernel does not support cgroup rt period"
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.066525408Z" level=warning msg="Your kernel does not support cgroup rt runtime"
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.068129407Z" level=warning msg="Unable to find cpuset cgroup in mounts"
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.072594403Z" level=warning msg="mountpoint for pids not found"
May 08 20:47:29 14d8bd6 balenad[858]: time="2020-05-08T20:47:29.104383375Z" level=info msg="Loading containers: start."
May 08 20:47:30 14d8bd6 balenad[858]: time="2020-05-08T20:47:30.740542959Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.ContainerDelete"
May 08 20:47:31 14d8bd6 balenad[858]: time="2020-05-08T20:47:31.070755673Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.ContainerDelete"
May 08 20:47:31 14d8bd6 balenad[858]: time="2020-05-08T20:47:31.168049589Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.ContainerDelete"
May 08 20:47:31 14d8bd6 balenad[858]: time="2020-05-08T20:47:31.440017354Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.ContainerDelete"
May 08 21:03:31 14d8bd6 balenad[858]: time="2020-05-08T21:03:31.887557599Z" level=info msg="Removing stale sandbox 4c8c65161b15d49e3239121adbaa0472a0554393efd32063d8e3f8f8dadc1ecf (bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb)"
May 08 21:03:31 14d8bd6 balenad[858]: time="2020-05-08T21:03:31.926366720Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 1493784db70e54fea9a6058c92f8371a43d103e9961de8c51a1be9de8a62cc4c], retrying...."
May 08 21:03:32 14d8bd6 balenad[858]: time="2020-05-08T21:03:32.867245613Z" level=info msg="Removing stale sandbox c149466b673b25663c7fadcb6b4f60bba2ebeec92b8b663b042503fe64d61912 (4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced)"
May 08 21:03:33 14d8bd6 balenad[858]: time="2020-05-08T21:03:33.137394380Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint f538d0fbe9b4058ccc245c34ca2049c6c00f50e87f7f5f5ccd717041bfb357fe 54bd447d44ddeaec4d814ae4c68880f9d3a143ed5b0799ed31810408a570691e], retrying...."
May 08 21:03:33 14d8bd6 balenad[858]: time="2020-05-08T21:03:33.208621318Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint 6cf26136eb75e4b20533f02a7d27aab02eeddc5892a23b03880e0579e1164dc0 68d2ea2b31d4b4dba255cc0b24dc2d2f3abb3e3257e6117495545ea0a2d57966], retrying...."
May 08 21:03:34 14d8bd6 balenad[858]: time="2020-05-08T21:03:34.152647503Z" level=info msg="Removing stale sandbox c36828a6805f6fd04ce4db51a6bae310ea59e7d9580d9740e62b03395d3f579d (708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02)"
May 08 21:03:34 14d8bd6 balenad[858]: time="2020-05-08T21:03:34.186606474Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 73ca4661b14fd39e39949a65099f83ad41b4da1886c9b5af9798957efee4f7d7], retrying...."
May 08 21:03:35 14d8bd6 balenad[858]: time="2020-05-08T21:03:35.170137624Z" level=info msg="Removing stale sandbox 1f5bf3e8f46cde2c885f774cad62033b6fb5bae0eb25c2eccd5508adb8536250 (66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790)"
May 08 21:03:35 14d8bd6 balenad[858]: time="2020-05-08T21:03:35.193651604Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 547131139dbb152c97d7a400b9c9f5357226dd5c19930480be049a0b757a2bc1], retrying...."
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41.000208590Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41.022758570Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41.024388569Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb/shim.sock debug=false module=containerd/tasks pid=1254
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced/shim.sock debug=false module=containerd/tasks pid=1259
May 08 21:03:41 14d8bd6 balenad[858]: time="2020-05-08T21:03:41Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02/shim.sock debug=false module=containerd/tasks pid=1260
May 08 21:03:47 14d8bd6 balenad[858]: time="2020-05-08T21:03:47.399993063Z" level=warning msg="unknown container" container=bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb module=libcontainerd namespace=plugins.moby
May 08 21:03:49 14d8bd6 balenad[858]: time="2020-05-08T21:03:49.972487842Z" level=warning msg="unknown container" container=bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb module=libcontainerd namespace=plugins.moby
May 08 21:03:50 14d8bd6 balenad[858]: time="2020-05-08T21:03:50.065137762Z" level=warning msg="unknown container" container=708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02 module=libcontainerd namespace=plugins.moby
May 08 21:03:54 14d8bd6 balenad[858]: time="2020-05-08T21:03:54.248571149Z" level=warning msg="unknown container" container=708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02 module=libcontainerd namespace=plugins.moby
May 08 21:03:56 14d8bd6 balenad[858]: time="2020-05-08T21:03:56.071371575Z" level=warning msg="unknown container" container=4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced module=libcontainerd namespace=plugins.moby
May 08 21:03:57 14d8bd6 balenad[858]: time="2020-05-08T21:03:57.227285577Z" level=warning msg="unknown container" container=4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced module=libcontainerd namespace=plugins.moby
May 08 21:03:58 14d8bd6 balenad[858]: time="2020-05-08T21:03:58.540066443Z" level=info msg="Loading containers: done."
May 08 21:03:59 14d8bd6 balenad[858]: time="2020-05-08T21:03:59.725887419Z" level=info msg="Docker daemon" commit=fe78e2c9a69313007c53c83fff4b5525fbc2ba45 graphdriver(s)=aufs version=17.13.3-dev
May 08 21:03:59 14d8bd6 balenad[858]: time="2020-05-08T21:03:59.730914415Z" level=info msg="Daemon has completed initialization"
May 08 21:04:00 14d8bd6 balenad[858]: time="2020-05-08T21:04:00.525561729Z" level=info msg="API listen on /var/run/balena-engine.sock"
May 08 21:04:00 14d8bd6 balenad[858]: time="2020-05-08T21:04:00.664180609Z" level=info msg="API listen on /var/run/balena-engine.sock"
May 08 21:04:00 14d8bd6 balenad[858]: time="2020-05-08T21:04:00.680297595Z" level=info msg="API listen on /var/run/balena.sock"
May 08 21:04:18 14d8bd6 balenad[858]: time="2020-05-08T21:04:18.330740353Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:04:18 14d8bd6 balenad[858]: time="2020-05-08T21:04:18Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790/shim.sock debug=false module=containerd/tasks pid=1594
May 08 21:04:23 14d8bd6 balenad[858]: time="2020-05-08T21:04:23.815411617Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
May 08 21:04:25 14d8bd6 balenad[858]: time="2020-05-08T21:04:25.956926767Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
-- Reboot --
May 08 21:10:45 14d8bd6 balenad[2782]: time="2020-05-08T21:10:45Z" level=warning msg="Running experimental build"
May 08 21:10:45 14d8bd6 balenad[2782]: time="2020-05-08T21:10:45.908477765Z" level=info msg="libcontainerd: started new balena-engine-containerd process" pid=2792
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="starting containerd" module=containerd revision= version=1.0.0+unknown
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="setting subreaper..." module=containerd
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="changing OOM score to -500" module=containerd
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." module=containerd type=io.containerd.content.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." module=containerd type=io.containerd.snapshotter.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." module=containerd type=io.containerd.metadata.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." module=containerd type=io.containerd.differ.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." module=containerd type=io.containerd.gc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." module=containerd type=io.containerd.monitor.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." module=containerd type=io.containerd.runtime.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." module=containerd type=io.containerd.grpc.v1
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd-debug.sock module=containerd/debug
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock module=containerd/grpc
May 08 21:10:46 14d8bd6 balenad[2782]: time="2020-05-08T21:10:46Z" level=info msg="containerd successfully booted in 0.164454s" module=containerd
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.242087340Z" level=info msg="Graph migration to content-addressability took 0.00 seconds"
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.249466238Z" level=warning msg="Your kernel does not support cgroup rt period"
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.250842219Z" level=warning msg="Your kernel does not support cgroup rt runtime"
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.252739193Z" level=warning msg="Unable to find cpuset cgroup in mounts"
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.255365157Z" level=warning msg="mountpoint for pids not found"
May 08 21:10:47 14d8bd6 balenad[2782]: time="2020-05-08T21:10:47.268991968Z" level=info msg="Loading containers: start."
May 08 21:10:54 14d8bd6 balenad[2782]: time="2020-05-08T21:10:54.548852389Z" level=info msg="Removing stale sandbox 1ae5b643fabcb2dbd04bb315d875fc47f8ea837017755e8f77943e53db9a7887 (708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02)"
May 08 21:10:54 14d8bd6 balenad[2782]: time="2020-05-08T21:10:54.581383940Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 74b94c740eae1d61a2995f2a2466413f62a3f2f4d4806f636b213d46ad2dba5c], retrying...."
May 08 21:10:55 14d8bd6 balenad[2782]: time="2020-05-08T21:10:55.531179817Z" level=info msg="Removing stale sandbox 33911e05f495848345a8a30f0a94a8e841a604ddf5a01b61c0e219460c06bb90 (4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced)"
May 08 21:10:55 14d8bd6 balenad[2782]: time="2020-05-08T21:10:55.823014785Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint f538d0fbe9b4058ccc245c34ca2049c6c00f50e87f7f5f5ccd717041bfb357fe 72299fa5df3517fe2f8946ae9f6116182a6d9ed478e6b3176900cb525acd5334], retrying...."
May 08 21:10:55 14d8bd6 balenad[2782]: time="2020-05-08T21:10:55.891725836Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint 6cf26136eb75e4b20533f02a7d27aab02eeddc5892a23b03880e0579e1164dc0 534580f55fe034f411bd1598b77851d39fa9e84fbced691b2e115670b22683b8], retrying...."
May 08 21:10:56 14d8bd6 balenad[2782]: time="2020-05-08T21:10:56.854318537Z" level=info msg="Removing stale sandbox 4105c63a4f63804e1dae337f16edfe66c85b550f9121a7de9503517702a0036b (66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790)"
May 08 21:10:56 14d8bd6 balenad[2782]: time="2020-05-08T21:10:56.884408121Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 9a43f56f98f43cd4bcb611d84db9b1129f1bc5f67a356869c917188239ff0c03], retrying...."
May 08 21:10:58 14d8bd6 balenad[2782]: time="2020-05-08T21:10:58.088502485Z" level=info msg="Removing stale sandbox 79c74997f802afb068ded080e4c665f56bf4b3910cd629fbbc99dc40211e96e7 (bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb)"
May 08 21:10:58 14d8bd6 balenad[2782]: time="2020-05-08T21:10:58.111626166Z" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint b19dc00647e8e09b6ef01460af8d27d56cabb87dbbace6b6a69e5617925d2839 5df599ce57f2897f1171fe72ed3d4390150fe1cf67d51f5d8e9bdc56d26a478a], retrying...."
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03.116090024Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03.122376937Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03.432584651Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02/shim.sock debug=false module=containerd/tasks pid=3054
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb/shim.sock debug=false module=containerd/tasks pid=3055
May 08 21:11:03 14d8bd6 balenad[2782]: time="2020-05-08T21:11:03Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced/shim.sock debug=false module=containerd/tasks pid=3063
May 08 21:11:10 14d8bd6 balenad[2782]: time="2020-05-08T21:11:10.180306424Z" level=warning msg="unknown container" container=708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02 module=libcontainerd namespace=plugins.moby
May 08 21:11:10 14d8bd6 balenad[2782]: time="2020-05-08T21:11:10.607205526Z" level=warning msg="unknown container" container=bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb module=libcontainerd namespace=plugins.moby
May 08 21:11:14 14d8bd6 balenad[2782]: time="2020-05-08T21:11:14.413096944Z" level=warning msg="unknown container" container=708a520b5b04a2014adc4f8ddcaac77ea79e3a4a3362141715fa0fc1c8f4de02 module=libcontainerd namespace=plugins.moby
May 08 21:11:15 14d8bd6 balenad[2782]: time="2020-05-08T21:11:15.001250818Z" level=warning msg="unknown container" container=bc95564f21246dcf9402daa1c401f2d861d659b8d8d5773b44bbd69b31f732fb module=libcontainerd namespace=plugins.moby
May 08 21:11:16 14d8bd6 balenad[2782]: time="2020-05-08T21:11:16.738807811Z" level=warning msg="unknown container" container=4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced module=libcontainerd namespace=plugins.moby
May 08 21:11:19 14d8bd6 balenad[2782]: time="2020-05-08T21:11:19.011430413Z" level=warning msg="unknown container" container=4db401c6ece3404162e35b968e68526ddcbf17e4108ac0cf248554d08da6aced module=libcontainerd namespace=plugins.moby
May 08 21:11:20 14d8bd6 balenad[2782]: time="2020-05-08T21:11:20.181056253Z" level=info msg="Loading containers: done."
May 08 21:11:21 14d8bd6 balenad[2782]: time="2020-05-08T21:11:21.342763203Z" level=info msg="Docker daemon" commit=fe78e2c9a69313007c53c83fff4b5525fbc2ba45 graphdriver(s)=aufs version=17.13.3-dev
May 08 21:11:21 14d8bd6 balenad[2782]: time="2020-05-08T21:11:21.354774037Z" level=info msg="Daemon has completed initialization"
May 08 21:11:21 14d8bd6 balenad[2782]: time="2020-05-08T21:11:21.603836596Z" level=info msg="API listen on /var/run/balena-engine.sock"
May 08 21:11:21 14d8bd6 balenad[2782]: time="2020-05-08T21:11:21.625027303Z" level=info msg="API listen on /var/run/balena-engine.sock"
May 08 21:11:21 14d8bd6 balenad[2782]: time="2020-05-08T21:11:21.629704238Z" level=info msg="API listen on /var/run/balena.sock"
May 08 21:11:36 14d8bd6 balenad[2782]: time="2020-05-08T21:11:36.885077469Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.ContainerCreate"
May 08 21:11:37 14d8bd6 balenad[2782]: time="2020-05-08T21:11:37Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790/shim.sock debug=false module=containerd/tasks pid=3344
May 08 21:11:42 14d8bd6 balenad[2782]: time="2020-05-08T21:11:42.138027894Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
May 08 21:11:44 14d8bd6 balenad[2782]: time="2020-05-08T21:11:44.369482064Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
May 08 21:16:46 14d8bd6 balenad[2782]: time="2020-05-08T21:16:46.988318038Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
May 08 21:16:48 14d8bd6 balenad[2782]: time="2020-05-08T21:16:48.195029951Z" level=warning msg="unknown container" container=66bd12d0be5444b153d35d9a05531da7839989561287600755942ee92d8f0790 module=libcontainerd namespace=plugins.moby
errors in dmesg output after the reboot:
[ 326.093938] systemd-udevd[24]: seq 1518 '/devices/platform/soc/20202000.mmc/mmc_host/mmc0/mmc0:e624/block/mmcblk0/mmcblk0p3' is taking a long time
[ 446.094357] systemd-udevd[24]: seq 1518 '/devices/platform/soc/20202000.mmc/mmc_host/mmc0/mmc0:e624/block/mmcblk0/mmcblk0p3' killed
[ 446.106100] systemd-udevd[24]: worker [32] terminated by signal 9 (Killed)
[ 446.106199] systemd-udevd[24]: worker [32] failed while handling '/devices/platform/soc/20202000.mmc/mmc_host/mmc0/mmc0:e624/block/mmcblk0/mmcblk0p3'
Historically found that rebooting does fix issues but am curious to see how to get to the root of the issues and figure out how to avoid them because sometimes the devices go offline and then we have to send a technician to these remote sites in Columbia to power cycle them.
