Balena OS configure not working on windows
When trying to configure an image on Windows 10 Pro.
I only get the output Configuring operating system image but no configuration menu.
Started the CMD as Admin same problem.
Balena Login and balena devices works as expected.
The log output from the Command Line window:
balena os configure "d:\Users\Torben\Desktop\resin.img" --app myApp
Can you please run the command with DEBUG=1 BLUEBIRD_DEBUG=1 balena os configure ... and see if anything useful is logged? Long shot but, can you also try cding into the image directory and invoking the command with balena os configure resin.img ... to rule out bugs with handling of Windows paths?
