I just updated the OpenBalena to version v3.4.1 (latest version available right now) and using the latest balena-cli, version 12.46.2 but after I’m successfully logging in and try to run the following command: balena devices supported I get no device list.
Is there any additional setup that I’m not aware of?
Previous issue affects the way that I’m building the apps, using:
DEBUG=1 balena build --deviceType raspberry-pi --arch rpi --emulated
[debug] original argv0="balena" argv=[/home/user/balena-cli/balena,/snapshot/versioned-source/bin/balena,build,--deviceType,raspberry-pi,--arch,rpi,--emulated] length=8
[debug] new argv=[/home/user/balena-cli/balena,/snapshot/versioned-source/bin/balena,build,--deviceType,raspberry-pi,--arch,rpi,--emulated] length=8
[Debug] Parsing input...
[Debug] Loading project...
[Debug] Resolving project...
[Debug] docker-compose.yml file found at "/home/user/myProject"
[Debug] Creating project...
[Info] Building for rpi/raspberry-pi
[Build] Building services...
[Build] wifi-connect Preparing...
[Build] node-red Preparing...
[Build] google-iot Preparing...
[Info] Emulation is enabled
Killed
docker-compose.yml looks like:
version: '2.1'
services:
wifi-connect:
build: ./wifi-connect
restart: always
network_mode: host
privileged: true
labels:
io.balena.features.dbus: '1'
io.balena.features.firmware: '1'
environment:
PORTAL_SSID: 'AValue'
PORTAL_PASSPHRASE: 'APasswordValue'
BALENA_ARCH: rpi
BALENA_MACHINE_NAME: raspberry-pi
node-red:
build: ./node-red/node-red
volumes:
- 'volume-data:/data'
restart: always
privileged: true
network_mode: host
labels:
cap_add:
- SYS_RAWIO
devices:
- "/dev/mem:/dev/mem"
- "/dev/gpiomem:/dev/gpiomem"
- "/dev/i2c-1:/dev/i2c-1"
- "/dev/ttyUSB0:/dev/ttyUSB0"
expose:
- "80"
depends_on:
- "google-iot"
command: ["./wait-for-it/wait-for-it.sh", "google-iot:8883", "--", "echo", "Google IoT Service is up and running"]
environment:
USERNAME: 'AValume'
PASSWORD: 'AHashedPAsswordValue'
PORT: 1234
google-iot:
build: ./google-iot
volumes:
- 'volume-data:/data/google-iot'
restart: always
privileged: true
network_mode: host
depends_on:
- "wifi-connect"
command: ["./wait-for-it/wait-for-it.sh", "www.google.com:80", "--", "echo", "IoT device is connected to the internet!"]
expose:
- 8883
environment:
GOOGLE_IOT_PROJECT: myproject
GOOGLE_IOT_REGION: my-region
GOOGLE_IOT_REGISTRY: my-registry
GOOGLE_IOT_SERVICE_ACCOUNT_TOKEN: 'json-account-token'
volumes:
volume-data:
I get
balena-cli logs:
user@ubuntu:~/myProject$ balena devices supported
SLUG ALIASES ARCH NAME
user@ubuntu:~/myProject$ balena --version
12.46.2
OpenBalena logs:
balena@cloud:~/open-balena$ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORT
S NAMES
879a051c9071 openbalena_haproxy "/docker-entrypoint.…" 44 minutes ago Up 18 minutes 0.0.
0.0:80->80/tcp, :::80->80/tcp, 222/tcp, 3128/tcp, 5432/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 6379/tcp openb
alena_haproxy_1
37e628f69c00 balena/open-balena-vpn:v9.17.11 "/usr/bin/entry.sh" 44 minutes ago Up 18 minutes 80/t
cp, 443/tcp, 3128/tcp openb
alena_vpn_1
5537263ac70b balena/open-balena-api:v0.139.0 "/usr/bin/entry.sh" 44 minutes ago Up 18 minutes 80/t
cp openb
alena_api_1
f2448226a57b balena/open-balena-registry:v2.16.1 "/usr/bin/entry.sh" 44 minutes ago Up 18 minutes 80/t
cp openb
alena_registry_1
cb1356e7d194 openbalena_cert-provider "/entry.sh /usr/src/…" 44 minutes ago Up 18 minutes 80/t
cp openb
alena_cert-provider_1
26855836641b balena/open-balena-s3:v2.9.9 "/usr/bin/entry.sh" 44 minutes ago Up 18 minutes 80/t
cp openb
alena_s3_1
269449e0449c redis:alpine "docker-entrypoint.s…" 44 minutes ago Up 18 minutes 6379
/tcp openb
alena_redis_1
ffb2fd2251e1 balena/open-balena-db:v4.1.0 "/balena-entrypoint.…" 44 minutes ago Up 18 minutes 5432
/tcp openb
alena_db_1
