I’m running on a VM Ubuntu 20.04.2 LTS and I’m consistently getting the following
$ balena deploy jays_dev_testbed --build --emulated
[Build] device_control Successfully built f5b3bbc625b2
[Build] device_control Successfully tagged device_control_com_system_device_control:latest
[Build] device_control Waiting...
[Build] Built 1 service in 0:01
[Info] Creating release...
[Info] Pushing images to registry...
Retrying "registry2.balena-cloud.com/v2/a901d3fd358bffe2a6c1fac6c4e69327:latest" after 2.00s (1 of 3) due to: Error: net/http: TLS handshake timeout
Retrying "registry2.balena-cloud.com/v2/a901d3fd358bffe2a6c1fac6c4e69327:latest" after 2.80s (2 of 3) due to: Error: dial tcp: lookup registry2.balena-cloud.com: Temporary failure in name resolution
[Info] Saving release...
[Error] Deploy failed
I’ve seen this error message show up in docker repository timeout problems [Docker pull: TLS handshake timeout](https://serverfault.com/questions/908141/docker-pull-tls-handshake-timeout )
Their workaround doesn’t seem applicable
I do have a marginal Internet
Internet speed test
49.4 Mbps download
2.65 Mbps upload
and it has been flaky
Is there anything I can increase the timeout interval?
Hi @jdada. Welcome to the Forums!
Could you please let me know what you are trying to achieve? By running the balena deploy jays_dev_testbed --build --emulated command you manage to complete the build step as well implicitly by not specifying an image to upload.
Sorry it’s been so long to respond, we solved the problem by moving this process onto a aws ec2 instance where the upload finishes in a few10s of seconds the process completes successfully there. I I just ran exactly the same command and it completed successfully this time of a have been experiencing bad upload bandwidth for several days around the time of my posting. the file is exceptionally large
$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE registry2.balena-cloud.com/v2/ed8aa470194f227ce1d32f64ba9fad75 latest f5b3bbc625b2 3 weeks ago 3.26GB
device_control_com_system_device_control latest f5b3bbc625b2 3 weeks ago 3.26GB
I believe this contributes to the problem it takes well over 30 minutes to push the image.
Hi @jdada, no worries at all, I’m glad to hear moving to AWS EC2 got things moving fast enough for the timeout not to be a problem. We really appreciate you sharing the resolution too, so that other users who might experience the same can see what worked for you!
