I’m running Balena on a PC in my living room and while it’s updating, the Balena dashboard shows the temperature is around -1 degrees Celsius:
How does Balena estimate the temperature of devices? Is there a driver I need to change/update?
Hi there, what board are you running this on?
Hi, the supervisor uses the systeminformation to gather device metrics. Could you share more information about your hardware and balenaOS and supervisor versions? Thank you
