When i use balena cli in my pnpm monorepo i get an error message.
if i use balena deploy or balena build it gives me the same error.
Even if i try to push to a raspberrypi4 its the same.
[debug] new argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,build,-A,aarch64,-d,raspberrypi4-64,.] length=8
[debug] Deprecation check: 1.99573 days since last npm registry query for next major version release date.
[debug] Will not query the registry again until at least 7 days have passed.
[Debug] Parsing input...
[Debug] Loading project...
[Debug] Resolving project...
[Debug] docker-compose.yml file found at "/Users/xyz/abc/NusterKit"
[Debug] Creating project...
[Build] Building services...
[Build] mongodb Preparing...
[Build] nuster-turbine Preparing...
[Build] nuster-desktop Preparing...
[Build] weston Preparing...
[Build] wpe Preparing...
[Build] proxy Preparing...
[Build] wifi-connect Preparing...
[Info] Building for aarch64/raspberrypi4-64
[Info] Docker Desktop detected (daemon architecture: "aarch64")
[Info] Docker itself will determine and enable architecture emulation if required,
[Info] without balena-cli intervention and regardless of the --emulated option.
[debug] Event tracking error: Timeout awaiting 'response' for 0ms
[Build] Built 7 services in 0 seconds
[Error] Build failed.
No such file or directory: /Users/xyz/abc/NusterKit/node_modules/.pnpm/esbuild@0.16.10/node_modules/@esbuild/android-arm
Error: ENOENT: no such file or directory, stat '/Users/xyz/abc/NusterKit/node_modules/.pnpm/esbuild@0.16.10/node_modules/@esbuild/android-arm'
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
Im using a M1 Pro macbook pro as my dev machine.
I tried uninstalling balena-cli and updating it without any success.
If someone has an idea of what i should try next, it would be awersome.
Something is bothering me in the logs. You have an error No such file or directory: /Users/xyz/abc/NusterKit/node_modules...
but /Users/xyz/abc... is a MacOS path, your build should run inside a docker container so a linux environment (i’m not event taking into account the android-arm part which is non-sense as you will be targeting linux).
If there is no reference inside your project to absolute path (you should never do this, it makes you project painful to build on any other machine), that is probably due to a symbolic link or node configuration failing at some point.
A nice practice for node projects is to delete the “node_modules” folder before building your project, and then, in your Dockerfile do the npm i to download the correct version of the libraries for you target system.
The MacOS path might be related to how PNPM uses /node_modules/ with symlinks inside.
I just checked the pnpm documentation and they mentions about pnpm fetch which should solve this issue.
i do not thinks deleting node_modules before the build process helps because i’m using a .dockerignore file.
I going to investigate in this direction, and post an update here.
To update: I tried swithing to pnpm fetch as a fallback. The behavior is the same., just to be sure i tried building the project using docker-compose and it successfully built. I have no idea what is going on with balena-cli…
I also removed from my docker-compose.yml services that relied on nodeJS to be sure that npm/pnpm would never be called, and it did not work too.
i am wondering if balena-cli is clashing with my pnpm installation.
To be clear, i can still use the github action balena-deploy to build my project and it works.
It’s quite annoying because i cant develop locally.
I you have any idea of what i should try next, it would be awersome.
you are probably right about the symlinks, this was also my initial guess, and I think it can still stand somehow bypassing the .dockerignore file and messing with the generation.
It might also fail due to caching (you can run balena build with the --nocache option to prevent reusing cached build/config).
Do you keep having the same error message?
What bothers me is we don’t see the usual Step 1/X indicating the Dockerfile starts to be parsed. This can also come from the fact that on MacOS, docker is running into a virual linux environment, and balena-cli/docker might try to copy it’s context (the current folder) to this environment before starting the build. As a test you can move your node_modules folder to a parent directory if you don’t want to remove it and try to rebuild from there (as it seems the incriminated symlinks come from this folder).
