I’ve been using balena CLI for a while, however yesterday it just died on me and my shell refused to recognize the command. So I thought that it would be best to reinstall everything. I’ve followed the instructions in the balena-cli github project.
I’ve installed windows-build-tools@4.0.0
I’ve tried installing balena, using npm insatll balena-cli -g --production --unsafe-perm both in an administrator shell as well as a normal user one. Each time there are several gyp build errors, however I’m not quite sure why that happens, as if I understood correctly, installing windows-build-tools would fix that.
embedder : error : Could not open file 'C:\Program Files (x86)\Windows Kits\10\redist\wdf\x64\WdfCoInstaller01011.dll'. [C:\Users\confusetador\AppData\Roaming\npm\node_modules\balena-cli\node_modules\winusb-driver-generator\build\libwdi.vcxproj]
EMBED C:\Program Files (x86)\Windows Kits\10\redist\wdf\x64\WdfCoInstaller01011.dll
gyp ERR! build error
gyp ERR! stack Error: `C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.exe` failed with exit code: 1
gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
gyp ERR! stack at ChildProcess.emit (events.js:189:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Windows_NT 10.0.17763
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\confusetador\AppData\Roaming\npm\node_modules\balena-cli\node_modules\winusb-driver-generator
gyp ERR! node -v v10.15.1
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
I’m on a Windows 10 machine.
