I tried unsuccessfully to install balena-cli on my Ubuntu 18.04.2. I tried it:
- With and without sudo.
- Uninstall and reinstall npm,
- Removed ~/.node-gyp folder and then the ~/.npmrc and rebooted
- Installed node@10
I’m out of alternatives, can someone help me out?
npm install balena-cli -g --production --unsafe-perm
npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
/home/sylvain/.node_modules/bin/balena -> /home/sylvain/.node_modules/lib/node_modules/balena-cli/bin/balena
> ext2fs@1.0.26 install /home/sylvain/.node_modules/lib/node_modules/balena-cli/node_modules/ext2fs
> prebuild-install || node-gyp rebuild
sh: 1: prebuild-install: not found
internal/modules/cjs/loader.js:611
throw err;
Error: Cannot find module 'graceful-fs'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:609:15)
at Function.Module._load (internal/modules/cjs/loader.js:535:25)
at Module.require (internal/modules/cjs/loader.js:663:17)
at require (internal/modules/cjs/helpers.js:20:18)
at Object.<anonymous> (/usr/share/node-gyp/lib/node-gyp.js:12:10)
at Module._compile (internal/modules/cjs/loader.js:734:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:745:10)
at Module.load (internal/modules/cjs/loader.js:626:32)
at tryModuleLoad (internal/modules/cjs/loader.js:566:12)
at Function.Module._load (internal/modules/cjs/loader.js:558:3)
└── (empty)
npm WARN optional Skipping failed optional dependency /balena-cli/removedrive:
npm WARN notsup Not compatible with your operating system or architecture: removedrive@1.1.2
npm WARN optional Skipping failed optional dependency /balena-cli/denymount/macmount:
npm WARN notsup Not compatible with your operating system or architecture: macmount@1.0.0
npm WARN optional Skipping failed optional dependency /balena-cli/etcher-sdk/winusb-driver-generator:
npm WARN notsup Not compatible with your operating system or architecture: winusb-driver-generator@1.2.4
npm WARN balena-request@10.0.1 requires a peer of balena-auth@^2.0.0 but none was installed.
npm WARN resin-register-device@5.0.0 requires a peer of resin-request@^9.0.2 but none was installed.
npm ERR! Linux 4.15.0-45-generic
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "balena-cli" "-g" "--production" "--unsafe-perm"
npm ERR! node v8.10.0
npm ERR! npm v3.5.2
npm ERR! code ELIFECYCLE
npm ERR! ext2fs@1.0.26 install: `prebuild-install || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the ext2fs@1.0.26 install script 'prebuild-install || node-gyp rebuild'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the ext2fs package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! prebuild-install || node-gyp rebuild
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs ext2fs
npm ERR! Or if that isn't available, you can get their info via:
npm ERR! npm owner ls ext2fs
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/sylvain/Documents/source/mobius/npm-debug.log
npm ERR! code 1
sudo npm install balena-cli -g --production --unsafe-perm
/usr/local/bin/balena -> /usr/local/lib/node_modules/balena-cli/bin/balena
> ext2fs@1.0.26 install /usr/local/lib/node_modules/balena-cli/node_modules/ext2fs
> mountutils@1.3.16 install /usr/local/lib/node_modules/balena-cli/node_modules/mountutils
prebuild-install WARN install No prebuilt binaries found (target=11.9.0 runtime=node arch=x64 platform=linux)
throw err;
/usr/local/lib
└── (empty)
npm ERR! npm v3.5.2
npm ERR! mountutils@1.3.16 install: `prebuild-install || node-gyp rebuild`
npm ERR!
npm ERR! Failed at the mountutils@1.3.16 install script 'prebuild-install || node-gyp rebuild'.
npm ERR! If you do, this is most likely a problem with the mountutils package,
npm ERR! npm bugs mountutils
npm ERR! npm owner ls mountutils
npm ERR! code 1
