HI, I’m a relatively new user to Balena and I’ve been having problems when playing audio from Spotify over a wireless network to Balena. It will play fine for a few mins but then it starts pausing/stuttering for a bit and then it will be ok for a while. There seems to be no pattern to when it does it.
I’ve tried over two different wifi networks (Google Mesh and internet provider’s hub).
Could this be a network or Pi hardware issue?
Hardware : Rpi 3 1Gb
PSU: Rpi
Logs at point of failure:
snapcast-server 2022-05-23 12-28-27 [Info] (onResync) onResync (default): 441 ms
snapcast-client 2022-05-23 12-28-27 [Info] (Stream) abs(age > 500): 527660
snapcast-client 2022-05-23 12-28-27 [Info] (Alsa) Failed to get chunk
snapcast-client 2022-05-23 12-28-28 [Info] (Stream) Chunk: 0 0
When I try over bluetooth, the stuttering is worse and I get the log errors mentioned on the page you referenced.
I think I’ve disabled multi-room: I added a variable ‘SOUND_MODE’ to ‘STANDALONE’. Is this correct?
It hasn’t made a difference to the stuttering though., nor has using a wired connection only.
We recommend Sandisk Extreme Pro SD cards as they have shown consistent speed and reliability in our testing.
If you’re running out of ram, there isn’t much you can do other than increase the swapfile size, but that will wear out your SD card faster.
