One of our deployed devices fails to start the container after receiving latest code update. We have a single container setup, running on rpi zero w boards.
In this application are multiple other devices (same hw) running normally.
Host OS: balenaOS 2.29.2+rev1
Supervisor version: 9.0.1
Service is reported to be running in balena dashboard, but opening the terminal displays the following:
Spawning shell…
Application container must be running for a terminal to be started.
SSH session disconnected
Host OS terminal works normally.
Restarting, rebooting or stopping the service from the web dashboard gives:
request error: tunneling socket could not be established, cause=socket hang up
I’ve also tried the following tasks:
- push another code update (nothing happened)
- reboot from terminal (device did reboot, but the problem remains)
balena version command gives the following response:
Client:
Version: 17.12.0-dev
API version: 1.35
Go version: go1.9.7
Git commit: dceb2fc48071b78a8a828e0468a15a479515385f
Built: Tue Jan 15 10:27:55 2019
OS/Arch: linux/arm
Experimental: false
Orchestrator: swarm
Cannot connect to the balenaEngine daemon at unix:///var/run/balena-engine.sock. Is the balenaEngine daemon running?
systemctl command: systemctl --state=failed
0 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use ‘systemctl list-unit-files’.
Part of the response (it’s repeating periodically) from command journalctl --no-pager -u balena
Jun 27 14:25:35 91c516a balenad[25242]: Error starting daemon: layer does not exist
Jun 27 14:25:35 91c516a systemd[1]: balena.service: Main process exited, code=exited, status=1/FAILURE
Jun 27 14:25:35 91c516a systemd[1]: balena.service: Failed with result ‘exit-code’.
Jun 27 14:25:35 91c516a systemd[1]: Failed to start Balena Application Container Engine.
Jun 27 14:25:35 91c516a systemd[1]: balena.service: Service hold-off time over, scheduling restart.
Jun 27 14:25:35 91c516a systemd[1]: balena.service: Scheduled restart job, restart counter is at 957.
Jun 27 14:25:35 91c516a systemd[1]: Stopped Balena Application Container Engine.
Jun 27 14:25:35 91c516a systemd[1]: Starting Balena Application Container Engine…
Jun 27 14:25:36 91c516a balenad[25266]: time=“2019-06-27T14:25:36Z” level=warning msg=“Running experimental build”
Jun 27 14:25:37 91c516a balenad[25266]: time=“2019-06-27T14:25:37.045765016Z” level=info msg=“libcontainerd: started new balena-engine-containerd process” pid=25276
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“starting containerd” module=containerd revision= version=1.0.0+unknown
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“setting subreaper…” module=containerd
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“changing OOM score to -500” module=containerd
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.content.v1.content”…” module=containerd type=io.containerd.content.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.snapshotter.v1.overlayfs”…” module=containerd type=io.containerd.snapshotter.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.metadata.v1.bolt”…” module=containerd type=io.containerd.metadata.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.differ.v1.walking”…” module=containerd type=io.containerd.differ.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.gc.v1.scheduler”…” module=containerd type=io.containerd.gc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.containers”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.content”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.diff”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.events”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.healthcheck”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.images”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.leases”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.namespaces”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.grpc.v1.snapshots”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:38 91c516a balenad[25266]: time=“2019-06-27T14:25:38Z” level=info msg=“loading plugin “io.containerd.monitor.v1.cgroups”…” module=containerd type=io.containerd.monitor.v1
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=“loading plugin “io.containerd.runtime.v1.linux”…” module=containerd type=io.containerd.runtime.v1
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=“loading plugin “io.containerd.grpc.v1.tasks”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=“loading plugin “io.containerd.grpc.v1.version”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=“loading plugin “io.containerd.grpc.v1.introspection”…” module=containerd type=io.containerd.grpc.v1
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=serving… address=/var/run/balena-engine/containerd/balena-engine-containerd-debug.sock module=containerd/debug
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=serving… address=/var/run/balena-engine/containerd/balena-engine-containerd.sock module=containerd/grpc
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39Z” level=info msg=“containerd successfully booted in 0.357201s” module=containerd
Jun 27 14:25:39 91c516a balenad[25266]: time=“2019-06-27T14:25:39.540277957Z” level=warning msg=“failed to rename /var/lib/docker/tmp for background deletion: rename /var/lib/docker/tmp /var/lib/docker/tmp-old: file exists. Deleting synchronously”
