An up to date guide on how to setup Quectel EC25-E gsm module on Balena fin 1.1.1
Is there an up-to-date guide on how to set up this gsm module from scratch?
I found few guides online, but nothing worked so far.
tried qmicli and mmcli , got further with qmicli where it will connect for few seconds and disconnect right away.
Tried the tutorials from this links
https://techship.com/faq/how-to-guide-control-and-set-up-a-data-connection-in-linux-using-modemmanager-as-connection-manager/
https://techship.com/faq/how-to-step-by-step-set-up-a-data-connection-over-qmi-interface-using-qmicli-and-in-kernel-driver-qmi-wwan-in-linux/
https://lists.freedesktop.org/archives/libqmi-devel/2017-August/002410.htm
@krasi-georgiev what device are you using?
I updated the title with more details
@krasi-georgiev - send us some pictures of these once they are deployed! :slight_smile:
@krasi-georgiev could you please confirm if defining a connection profile on /etc/NetworkManager/system-connections/ solves this problem?
yes with your assistance it is all looking stable right now and the connection doesn’t interrupt.
/etc/NetworkManager/system-connections/krasi.nmconnection
[connection]
id=krasi
uuid=c51f46fc-c238-4fca-a0b5-23464003441e
type=gsm
permissions=
[gsm]
number=*99#
[ipv4]
dns-search=
method=auto
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
@dtischler here is the current progress will post more updates when we have it working with ML model from edge impulse
:partying_face:
