Hello all,
So I’m playing around with kiosk-like solutions.
I have a sweet setup where I am able to use electron running with Wayland.
This is setup is running into intel NUC.
I am now interested in having the same setup running into a NUC8i7HVK which contains an AMD Radeon RX Vega M GH graphics card.
(Ideally, I wish to have something compatible with all x86-64 devices with AMD graphical cards).
When I access to my electron container and run lshw -C display I get the output:
*-display UNCLAIMED
description: VGA compatible controller
product: Polaris 22 XT [Radeon RX Vega M GH]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: c0
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list
configuration: latency=0
resources: memory:90000000-9fffffff memory:a0000000-a01fffff ioport:e000(size=256) memory:db500000-db53ffff memory:c0000-dffff
*-display
description: Display controller
product: HD Graphics 630
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm bus_master cap_list
configuration: driver=i915 latency=0
resources: iomemory:2f0-2ef iomemory:2f0-2ef irq:161 memory:2ffe000000-2ffeffffff memory:2fa0000000-2fafffffff ioport:f000(size=64)
So as per my understanding the first *-display entry (the AMD one) being UNCLAIMED means there are no GPU modules capable of using it.
Looking into the second *-display entry we can spot the line configuration: driver=i915 referring to the available GPU driver in use.
Using the label io.balena.features.kernel-modules: '1' into my docker-compose file I was able to access the directory /lib/modules/5.14.21-yocto-standard/kernel/drivers/gpu/drm and check de available modules over there:
- i915
- tiny
- ttm
So I guess what I need is to be able to have the amd module here.
Already managed to download the proper kernel-source modules on my Dockerfile running:
RUN \
curl -fsSL "https://files.balena-cloud.com/images/${BALENA_MACHINE_NAME}/${VERSION}/kernel_source.tar.gz" \
| tar xz --strip-components=2 && \
Already verify I have the source files of the amd module there but I am still not able of making a .ko file I need.
Any suggestions will be very appreciated.
Thanks in advance,
Nuno
