alpine python container stopped building
hello
one of our unchanged containers has stopped building. Problem first noticed yesterday - Sun 23:00 and hasn’t corrected itself yet.
Earlier last week same happened on this service but sorted itself out after a few hours and builds went through OK again
FROM balenalib/%%BALENA_MACHINE_NAME%%-alpine-python:3.6
RUN apk add --no-cache ffmpeg-dev=4.2.1-r3
gcc=9.2.0-r4
python3-dev=3.8.2-r0
linux-headers=4.19.36-r0
musl-dev=1.1.24-r2
zlib-dev=1.2.11-r3
jpeg-dev=8-r6
&& rm -rf /var/cache/apk/*
2020-04-27T12:38:39.7831738Z e[31m[Error]e[39m Error: The command ‘/bin/sh -c apk add --no-cache ffmpeg-dev=4.2.1-r3 gcc=9.2.0-r4 python3-dev=3.8.2-r0 linux-headers=4.19.36-r0 musl-dev=1.1.24-r2 zlib-dev=1.2.11-r3 jpeg-dev=8-r6 && rm -rf /var/cache/apk/*’ returned a non-zero code: 1
Thanks for reporting this.
It seems like the latest build of alpine base images has an issue.
You can workaround this by replacing the FROM line of your Dockerfile with FROM balenalib/%%BALENA_MACHINE_NAME%%-alpine-python:3.6-3.11-run-20200405
I’ll provide this info to the base images maintainer, it should be fixed in the next versions.
great thanks for your help and suggestion
We have rebuilt most of our base images with the fix so your base images should be fixed now.
Please give it a try and let us know how it goes.
