Adding another parameter to cmdline.txt
Hi, thanks for your message. We have discussed internally the possibility of allowing customization of kernel command line arguments and agreed that it is not something we want to provide in our product. A solution that I am internally discussing is providing the spidev driver as a module instead of built in so it can be loaded from the application container with the appropriate parameters passed in. Could you please tell us what device type and BalenaOS version you are currently using?
