Add parameters to cmdline.txt for RPi devices in Dashboard
My hardware, which is based of the Raspberry Pi CM4 device, requires a device setting in cmdline.txt for the display to work. Currently I have to manually add this to the boot partition, but when I upgrade the OS that setting is lost. It would be great if the Supervisor had a feature to manage cmdline.txt additional parameters.
For reference, this is what I need to add to my cmdline.txt for my display to work: video=HDMI-A-1:800x480M-32@60D
For example, like we do with BALENA_HOST_CONFIG_xxx, it would be great to have a BALENA_HOST_CMDLINE custom configuration setting that the supervisor could append to the cmdline.txt (making sure it’s not adding it if it already exists).
Please!
+1 on this. We have cmdline.txt entries that are needed to boot with specific NVMEs. Please please!
I see you’re in the same boat as I am. Phison controllers?
This feature would be much much appreciated.
