Add Sane to pre build cups Application
Hey,
is it possible to add sane to the pre build Cups Application?
Best Regards
Hey @ER0STR4TUS, first of all welcome to the balena community!
It’s possible in theory for sure. How familiar are you with software development and balena ecosystem? Would you like to make an attempt to combine these projects yourself?
First we need to make sure that Sane scanner works fine on a balena device. This might require some changes on how that Sane project is built. Next, we would look into merging both of these projects in the same multi-container application.
We encourage you to start working on these. For sure the balena team is here to help with solving specific issues along the way.
Cheers…
