Accessing RS485 Interface on Compulab IOTDIN-IMX8P with Balena
Hello Forum,
I am currently evaluating the Compulab IOTDIN-IMX8P device with Balena. The provisioning and flashing processes were straightforward. However, I am encountering an issue with accessing the RS485 interface within a container.
On other hardware, I typically map the device in the docker-compose.yml file (e.g., /dev/ttyRS485:/dev/ttyRS485 with privileged: true), and the interface becomes accessible inside the container. On this device, though, while /dev/ttyRS485 is available on the HostOS, it does not appear inside the container after being mapped in the compose file.
Is there a specific configuration or hardware label required for accessing the RS485 interface on the Compulab IOTDIN-IMX8P?
Any guidance would be greatly appreciated.
Best regards,
Timo
Hi @TimoAtMUV, if the device node is available in the hostOS, using the devices: field in your composition for a specific service should make it available to the container.
Could you provide the compose file you are using?
Hardware interface is directly accessible via /dev/ttyRS485 now.
I’ve used the mappings:
devices:
 \# ---- Logical serial ports ----
  - '/dev/ttymxc2:/dev/ttyRS232'
  - '/dev/ttymxc3:/dev/ttyRS485'
  \# ---- Modem / USB serial ----
  - '/dev/ttyUSB0:/dev/ttyModemQCDM'
  - '/dev/ttyUSB1:/dev/ttyModemGPS'
  - '/dev/ttyUSB2:/dev/ttyModemAT1'
  - '/dev/ttyUSB3:/dev/ttyModemAT2'
  \# ---- Input button ----
  - '/dev/input/event1:/dev/input/event1'
in my docker compose.
