Hi. Are you able to build the code on your side in order to try an updated kernel? We have a work in progress PR for this https://github.com/balena-os/balena-allwinner/pull/125
If you cannot build it, then you’d need to wait for a little while until we merge it and the new OS version will be available in the dashboard
