Wifi-Connect - ui and dnsmasq
I use Yocto and would like to use WiFi-Connect. I have a question: can I change the CSS, the look and feel, and the logo? Also, how is the license?
On another note, I have a defined DNSmasq service. The main reason for this is that I only have a rootfs that is mounted as read-only. Could you please help me with this?
Fabian
Hello @Climber1987mux first of all welcome to the balena community!
You can find the WiFi-connect project here GitHub - balena-os/wifi-connect: Easy WiFi setup for Linux devices from your mobile phone or laptop
Find the license here and I think the license allows you to make changes and use it.
Let us know what are your next steps here!
Hi there, thank you for your warm welcome.
I’m having a problem with dnsmasq, and I’m not sure how to debug it. It seems like the DNS server is returning a „defunct“ response. Can you help me out?
@Climber1987mux could you please share more details and logs?
I resolved the issue with dnsmasq. However, I’m facing another problem: I have a connection, but it doesn’t load.
Here’s a list of the connections I have:
  • Abinauten5g.nmconnection: This is my home connection.
  • test.nmconnection: This is my web app connection.
Despite having these connections, the web app doesn’t load.
my question are:
where the configuration file are?
the main reason are my root fs is readonly
my linux is yocto
thank you for your help :slight_smile:
I think @alanb128 mentioned me that there is a newer WiFi Connect version or almost ready to get released. Let’s see if that will fix your issue @Climber1987mux
Sorry, thank you. It’s old version.
Can I build the app from sources? the main cause is it better for Yocto.
What did I need? I get three errors:
error[E0119]****: conflicting implementations of trait Trait for type (dyn Send + Sync + 'static)
→ /home/vboxuser/.cargo/registry/src/index.crates.io-1949cf8c6b5b557f/traitobject-0.1.0/src/impls.rs:72:1
71 | unsafe impl Trait for ::std::marker::Send + Sync { }
| ------------------------------------------------ first implementation here
72 | unsafe impl Trait for ::std::marker::Send + Send + Sync { }
| ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ conflicting implementation for (dyn Send + Sync + 'static)
→ /home/vboxuser/.cargo/registry/src/index.crates.io-1949cf8c6b5b557f/traitobject-0.1.0/src/impls.rs:73:1
73 | unsafe impl Trait for ::std::marker::Sync + Send { }
→ /home/vboxuser/.cargo/registry/src/index.crates.io-1949cf8c6b5b557f/traitobject-0.1.0/src/impls.rs:75:1
75 | unsafe impl Trait for ::std::marker::Sync + Send + Sync { }
For more information about this error, try rustc --explain E0119
this was my calling statement:
cargo build --release --target=aarch64-unknown-linux-gnu
