WiFi-connect installation in Raspberry Pi Docker container
Hey, Anatoli, at this point we can’t really do anything to help you, because this has nothing to do with Balena.
I would recommend you switch your containers to use Balena, and at that point we can continue to provide support.
The first ten devices are free, so it won’t cost anything for testing, and you can always switch back to docker later on if you want
Thanks for your help so far.
My last silly question.
Switching the container to use Balena is mean to change the base image in Dockerfile to balena OS?
Or does it mean to install Balena OS on host OS, not Raspbian?
Anatoli
That’s actually the device-type and depends on the device you’re using: https://www.balena.io/docs/reference/base-images/devicetypes/
