Yes I have tried to manually enter the container for debugging purpose but using the image id which is configured properly.
Also as you saw there is issue when the build fails But I faced the same issue even when build succeeded.
Note I am using balena push <ip-address> for pushing the code locally.
@Sharvin26 thanks for the report. I’ve only managed to reproduce this on a failed build, so it appears that we need to do some extra cleanup on a non-failed build.
You mentioned that you saw this one a successful build, is that reproducible?
I’ve made this issue for now, and I’ll try and sort it out asap: https://github.com/balena-io/balena-cli/issues/1236
As it turns out the fix was fairly easy, I’ve put up a PR here: https://github.com/balena-io/balena-cli/pull/1237
@Sharvin26, the fix mentioned by Cameron has been released to the CLI version 10.13.2 (or later). Installation instructions: https://github.com/balena-io/balena-cli/blob/master/INSTALL.md
Let us know if it improves the situation!
The issue for Container has been fixed but it still persists for Image.
➜ balena version
10.13.3
I made some changes in the code and pushed the code locally using balena push <ip-address> and then I got this result:
root@mydevice:~# balena images
REPOSITORY TAG IMAGE ID CREATED SIZE
local_image latest d657a18e06c0 About a minute ago 259MB
<none> <none> b9538be2fb0b 17 hours ago 259MB
balena/armv7hf-supervisor v9.0.1 835f656b8cea 5 months ago 53.5MB
root@mydevice:~# balena ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
69a1a67f17f9 d657a18e06c0 "/usr/bin/entry.sh /…" 3 minutes ago Restarting (0) 36 seconds ago local_image_1.1
d2014593293e balena/armv7hf-supervisor:v9.0.1 "./entry.sh" 19 years ago Up 8 minutes (healthy) resin_supervisor
According to my understanding, it should destroy the old image when it created a new image.
The dangling images are not removed as per normal docker operation. You can delete them yourself by using this helpful command.
docker rmi $(docker images -f "dangling=true" -q)
Yes right now I am using this command
Is there any way I can remove them automatically?
At this point, I think the usual way is to manually use the command you just mentioned.
ZubairLK
I think that this is actually something the supervisor could do, without much of a problem for anything else going on on the device.
I’ve created an issue to track it here: https://github.com/balena-io/balena-supervisor/issues/993
That’s great to know that supervisor can remove the dangling images.
