I’m trying to set up a RPi 3 as a web server using the public URL. I’ve set up the device with Balena Wifi Connect, and I’m not sure if this is causing an issue.
My docker-compose.yml file is:
version: "2.1"
services:
    wifi-connect:
    build: ./wifi-connect-master
    network_mode: "host"
    labels:
        io.balena.features.dbus: '1'
    cap_add:
        - NET_ADMIN
    environment:
        DBUS_SYSTEM_BUS_ADDRESS: "unix:path=/host/run/dbus/system_bus_socket"
Web_Server:
    build: ./Web_Server
    privileged: true
    expose:
      - "80"
I’m just getting an error saying:
We encountered an error when reaching this [balena.io](https://balena.io/) device:
UUID 3ba5b6d5dc930ca665225936bfd3c62e
`tunneling socket could not be established: 500`
One possible reason is because nothing is listening on port 80 on the device.
I’ve granted support access and my UUID is 3ba5b6d5dc930ca665225936bfd3c62e
I got the code from https://github.com/balenalabs/balena-python-hello-world/blob/master/Dockerfile.template
