Use standard YYYY-MM-DD for timestamps in logs
The timestamps in the logs are really confusing; at a glance I am often thinking that they are from a different month. It would be nice to use more standard timestamp formatting for the day.
See the attached image; it would be much more readable as
2023-04-02 22:40:56 (-0700)
Among other benefits, it lexicographically sorts! But I’m just so used to seeing timestamps with the YYYY-MM-DD in logs that I get confused more than helped by the current format.
Matt set the status to Completed
Hello, thank you for requesting this feature. We have discussed it internally and have agreed to use the standard ISO format for timestamps, as outlined here: ISO 8601 - Wikipedia
This feature is now live and completed as of dashboard version 19.6.5
