I have restarted the system and the container had trouble starting the USB device the first few attempts. Nothing of note in dmesg.
First device we want to get working at /dev/ttyUSB0 is idVendor=10c4, idProduct=8a5b.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.98 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP Fri Mar 22 06:23:54 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3dc00000
[ 0.000000] On node 0 totalpages: 255488
[ 0.000000] free_area_init_node: node 0, pgdat 8148aec0, node_mem_map bd336000
[ 0.000000] Normal zone: 2246 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 255488 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x448 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @be59c000 s38796 r8192 d22644 u69632
[ 0.000000] pcpu-alloc: s38796 r8192 d22644 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 253242
[ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=null rootfstype=ext4 rootwait vt.global_cursor_default=0 root=PARTUUID=cf17c89d-02 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 982732K/1021952K available (8192K kernel code, 600K rwdata, 2256K rodata, 8192K init, 705K bss, 31028K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbe800000 - 0xff800000 (1040 MB)
lowmem : 0x80000000 - 0xbe600000 ( 998 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80900000 (9184 kB)
.init : 0x80c00000 - 0x81400000 (8192 kB)
.data : 0x81400000 - 0x8149621c ( 601 kB)
.bss : 0x8149e6e4 - 0x8154ee30 ( 706 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27624 entries in 82 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000277] Console: colour dummy device 80x30
[ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000330] pid_max: default: 32768 minimum: 301
[ 0.000646] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000666] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001522] CPU: Testing write buffer coherency: ok
[ 0.001952] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002374] Setting up static identity map for 0x100000 - 0x10003c
[ 0.002502] Hierarchical SRCU implementation.
[ 0.003188] smp: Bringing up secondary CPUs ...
[ 0.003960] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004774] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.005567] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.005673] smp: Brought up 1 node, 4 CPUs
[ 0.005701] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.005710] CPU: All CPU(s) started in HYP mode.
[ 0.005718] CPU: Virtualization extensions available.
[ 0.006661] devtmpfs: initialized
[ 0.017320] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.017538] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017560] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.018140] pinctrl core: initialized pinctrl subsystem
[ 0.018885] NET: Registered protocol family 16
[ 0.021468] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.026153] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.026166] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.026379] Serial: AMBA PL011 UART driver
[ 0.028125] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.028582] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.059762] bcm2835-dma 3f007000.dma: DMA legacy API manager at be813000, dmachans=0x1
[ 0.061312] SCSI subsystem initialized
[ 0.061539] usbcore: registered new interface driver usbfs
[ 0.061595] usbcore: registered new interface driver hub
[ 0.061685] usbcore: registered new device driver usb
[ 0.070076] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-11-04 16:32
[ 0.071352] clocksource: Switched to clocksource arch_sys_counter
[ 0.153617] VFS: Disk quotas dquot_6.6.0
[ 0.153709] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.153898] FS-Cache: Loaded
[ 0.154107] CacheFiles: Loaded
[ 0.162966] NET: Registered protocol family 2
[ 0.163687] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.163801] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.163991] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.164124] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.164172] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.164398] NET: Registered protocol family 1
[ 0.164934] RPC: Registered named UNIX socket transport module.
[ 0.164946] RPC: Registered udp transport module.
[ 0.164955] RPC: Registered tcp transport module.
[ 0.164964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.224240] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.226977] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.234654] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.234924] FS-Cache: Netfs 'nfs' registered for caching
[ 0.235541] NFS: Registering the id_resolver key type
[ 0.235587] Key type id_resolver registered
[ 0.235597] Key type id_legacy registered
[ 0.235617] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.236830] aufs 4.14.73+-20190211
[ 0.238044] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.238170] io scheduler noop registered
[ 0.238182] io scheduler deadline registered
[ 0.238346] io scheduler cfq registered (default)
[ 0.238358] io scheduler mq-deadline registered
[ 0.238368] io scheduler kyber registered
[ 0.240728] BCM2708FB: allocated DMA memory fdd00000
[ 0.240761] BCM2708FB: allocated DMA channel 0 @ be813000
[ 0.245769] Console: switching to colour frame buffer device 82x26
[ 0.250139] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.250277] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 0.250736] vc-sm: Videocore shared memory driver
[ 0.251018] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.260417] brd: module loaded
[ 0.269243] loop: module loaded
[ 0.269264] Loading iSCSI transport class v2.0-870.
[ 0.269943] libphy: Fixed MDIO Bus: probed
[ 0.269985] tun: Universal TUN/TAP device driver, 1.6
[ 0.270146] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.270405] dwc_otg 3f980000.usb: base=0xf0980000
[ 0.470587] Core Release: 2.80a
[ 0.470600] Setting default values for core params
[ 0.470628] Finished setting default values for core params
[ 0.670867] Using Buffer DMA mode
[ 0.670878] Periodic Transfer Interrupt Enhancement - disabled
[ 0.670888] Multiprocessor Interrupt Enhancement - disabled
[ 0.670898] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.670925] Dedicated Tx FIFOs mode
[ 0.671298] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbdd14000 dma = 0xfdd14000 len=9024
[ 0.671327] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.671375] dwc_otg: Microframe scheduler enabled
[ 0.671430] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80647c48
[ 0.671446] WARN::hcd_init_fiq:460: FIQ ASM at 0x80647fa4 length 36
[ 0.671463] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.671520] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.671556] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.671591] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.671642] Init: Port Power? op_state=1
[ 0.671651] Init: Power Port (0)
[ 0.671855] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.671870] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.671883] usb usb1: Product: DWC OTG Controller
[ 0.671896] usb usb1: Manufacturer: Linux 4.14.98 dwc_otg_hcd
[ 0.671908] usb usb1: SerialNumber: 3f980000.usb
[ 0.672502] hub 1-0:1.0: USB hub found
[ 0.672545] hub 1-0:1.0: 1 port detected
[ 0.673018] dwc_otg: FIQ enabled
[ 0.673024] dwc_otg: NAK holdoff enabled
[ 0.673028] dwc_otg: FIQ split-transaction FSM enabled
[ 0.673037] Module dwc_common_port init
[ 0.673251] usbcore: registered new interface driver usb-storage
[ 0.673418] mousedev: PS/2 mouse device common for all mice
[ 0.673493] IR NEC protocol handler initialized
[ 0.673503] IR RC5(x/sz) protocol handler initialized
[ 0.673512] IR RC6 protocol handler initialized
[ 0.673521] IR JVC protocol handler initialized
[ 0.673529] IR Sony protocol handler initialized
[ 0.673538] IR SANYO protocol handler initialized
[ 0.673547] IR Sharp protocol handler initialized
[ 0.673556] IR MCE Keyboard/mouse protocol handler initialized
[ 0.673565] IR XMP protocol handler initialized
[ 0.674249] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.674521] bcm2835-cpufreq: min=600000 max=1400000
[ 0.674913] sdhci: Secure Digital Host Controller Interface driver
[ 0.674923] sdhci: Copyright(c) Pierre Ossman
[ 0.675284] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.675610] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.675711] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.679087] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.679158] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.679219] usbcore: registered new interface driver usbhid
[ 0.679223] usbhid: USB HID core driver
[ 0.679531] vchiq: vchiq_init_state: slot_zero = bdd80000, is_master = 0
[ 0.680410] [vc_sm_connected_init]: start
[ 0.683156] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 0.683160] [vc_sm_connected_init]: failed to initialize shared memory service
[ 0.683168] [vc_sm_connected_init]: end - returning -1
[ 0.683537] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.683884] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.684166] Initializing XFRM netlink socket
[ 0.684458] NET: Registered protocol family 10
[ 0.684912] Segment Routing with IPv6
[ 0.684948] NET: Registered protocol family 17
[ 0.684974] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.685016] Key type dns_resolver registered
[ 0.685190] Registering SWP/SWPB emulation handler
[ 0.685482] registered taskstats version 1
[ 0.688347] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.688393] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.689331] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.689338] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.741979] sdhost: log_buf @ bdd13000 (fdd13000)
[ 0.779214] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.780707] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.782200] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.784960] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.821373] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.822333] of_cfs_init
[ 0.822415] of_cfs_init: OK
[ 0.822718] Warning: unable to open an initial console.
[ 0.835041] Freeing unused kernel memory: 8192K
[ 0.873049] random: fast init done
[ 0.880289] mmc1: new high speed SDIO card at address 0001
[ 0.891558] Indeed it is in host mode hprt0 = 00021501
[ 0.992532] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.996586] mmc0: new high speed SDHC card at address aaaa
[ 0.996975] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 1.000742] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.101434] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.101595] Indeed it is in host mode hprt0 = 00001101
[ 1.128880] udevd[256]: starting version 237
[ 1.341779] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 1.341804] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.342510] hub 1-1:1.0: USB hub found
[ 1.342615] hub 1-1:1.0: 4 ports detected
[ 1.661384] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.791551] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
[ 1.791564] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.791948] hub 1-1.1:1.0: USB hub found
[ 1.791994] hub 1-1.1:1.0: 3 ports detected
[ 1.891454] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 2.028600] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=8a5b
[ 2.028626] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.028640] usb 1-1.3: Product: CEL EM3588 Zigbee USB Stick
[ 2.028653] usb 1-1.3: Manufacturer: Silicon Labs
[ 2.028665] usb 1-1.3: SerialNumber: 013C82CA
[ 2.219744] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.266792] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.571456] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 2.701649] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
[ 2.701662] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.927332] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 2.938229] aufs au_opts_verify:1609:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[ 3.328533] systemd[1]: System time before build time, advancing clock.
[ 3.353907] systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.354194] systemd[1]: Detected architecture arm.
[ 3.357613] systemd[1]: No hostname configured.
[ 3.357634] systemd[1]: Set hostname to <localhost>.
[ 3.364958] systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0
[ 3.364985] systemd[1]: Set hardware watchdog to 10s.
[ 3.450237] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.450255] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.626962] systemd[1]: Unnecessary job for /dev/disk/by-label/resin-state was removed.
[ 3.626994] systemd[1]: Unnecessary job for /dev/disk/by-partuuid/cf17c89d-02 was removed.
[ 3.632187] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.632485] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.632672] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.925156] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.930794] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 4.992244] rtc-ds1307 1-0068: registered as rtc0
[ 5.071424] libphy: lan78xx-mdiobus: probed
[ 5.076836] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.178537] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.188747] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[ 5.189589] usbcore: registered new interface driver brcmfmac
[ 5.222173] usbcore: registered new interface driver lan78xx
[ 5.402063] random: crng init done
[ 5.402074] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.402494] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 5.477358] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 5.477763] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[ 6.379684] uart-pl011 3f201000.serial: no DMA platform data
[ 7.440214] i2c /dev entries driver
[ 7.455584] brcmfmac: power management disabled
[ 8.292412] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.295612] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.327484] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.352996] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.353031] brcmfmac: power management disabled
[ 8.874327] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.874376] brcmfmac: power management disabled
[ 8.952321] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 9.139287] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.834633] Bridge firewalling registered
[ 12.931653] Bluetooth: Core ver 2.22
[ 12.931707] NET: Registered protocol family 31
[ 12.931712] Bluetooth: HCI device and connection manager initialized
[ 12.931728] Bluetooth: HCI socket layer initialized
[ 12.931737] Bluetooth: L2CAP socket layer initialized
[ 12.931756] Bluetooth: SCO socket layer initialized
[ 12.953373] Bluetooth: HCI UART driver ver 2.3
[ 12.953400] Bluetooth: HCI UART protocol H4 registered
[ 12.953411] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 12.953667] Bluetooth: HCI UART protocol Broadcom registered
[ 13.129673] Netfilter messages via NETLINK v0.30.
[ 13.133761] ctnetlink v0.93: registering with nfnetlink.
[ 13.242463] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.242475] Bluetooth: BNEP filters: protocol multicast
[ 13.242488] Bluetooth: BNEP socket layer initialized
[ 13.704563] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[ 13.892530] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[ 14.094295] IPv6: ADDRCONF(NETDEV_UP): br-46430e63adbf: link is not ready
[ 19.960326] systemd-udevd[25]: starting version 232
[ 19.994622] systemd-udevd[25]: starting version 232
[ 22.001951] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 24.547962] usbcore: registered new interface driver usbserial
[ 24.548045] usbcore: registered new interface driver usbserial_generic
[ 24.548105] usbserial: USB Serial support registered for generic
[ 24.555761] usbcore: registered new interface driver cp210x
[ 24.555841] usbserial: USB Serial support registered for cp210x
[ 24.560495] cp210x 1-1.3:1.0: cp210x converter detected
[ 24.585672] usb 1-1.3: cp210x converter now attached to ttyUSB0
[ 114.464519] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 114.464584] brcmfmac: power management disabled
[ 117.592946] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 432.338445] usb 1-1.1.3: new high-speed USB device number 6 using dwc_otg
[ 432.478712] usb 1-1.1.3: New USB device found, idVendor=1fc9, idProduct=0083
[ 432.478725] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 432.478730] usb 1-1.1.3: Product: VCOM Port
[ 432.478736] usb 1-1.1.3: Manufacturer: NXP
[ 432.478742] usb 1-1.1.3: SerialNumber: NXP-77
[ 432.532760] cdc_acm 1-1.1.3:1.0: ttyACM0: USB ACM device
[ 432.533256] usbcore: registered new interface driver cdc_acm
[ 432.533267] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
